If you cannot get a gps lock try this
Indoors ( sim , gps and wifi all on )
Open google maps until you get a lock on location
Close google maps and turn of wifi
Go outside and see if gps works ( give it a while )
What do you think about waterproofness of Lem10?
What did you do so there is no GPS?
any modifications? Any firmawarw updates?
No issues for me with running etc and Gps super fast lock
@Dr_Andy_Vishnu what do you think about battery life if you are using the watch without sim card but with two apps which are connecting via BT with a CGM and a diabetes pump every 5 Min. for a few seconds? Or⦠how long lasts battery without simcard and wifi (only 20Mins./d), display ON about 1h/d?
Iām sure youāll get a hole day. For sure. Probably more.
I need at least 16 hours without charging; has the watch an app for disabling unnecessary background tasks, a battery saving app? I used a Jelly Pro for this special purpose and it was OK. Now I want to try it with one of these fullandroidwatches, it might be very comfortable for me because I have my SW3 watch day and night on my wrist.
16 hours should be no problem. You can use battery saver and disable just the app you need.
I got a DM20 1GB/16GB (sold by XGODY) (used, affordable price only for testing
) which should be the same watch as Lemfo LEM 10 - it works now with my Konfiguration and battery consumption is better than I thought.
Now another question: is the firmware exactly the same as LEM10s ? It seems to be very basic, but I donāt know if this is normal. Build Nr. shows: DM20_C10_V0.6_20191105 with Kernel Version: 4.4.22+ of the same date. Really donāt want to root it or use a custom rom if itās not necessary.
Iāll compare it next week with a friends Kospet Prime and we will see the difference, because we need it only for usage with two rectangular apps.
Hi
Do you know if the rom of DM20 is exactly the same as of LEM10?
DM20 is the same but be careful, it has to be the exact firmware meaning 1/16 GB not the 3/32 GB.
It would be interesting to see a comparison between version 1/16 vs 3/32. But I think itās hard to find.
I suppose the smaller version has some performance problems caused by the small RAM. Iām using now systems background cleaner to block all unnecessary apps to avoid staying in background.
since BT consumes a lot of power, I would take 3GB + 16GB, but there is no such watch. I wouldnāt take anything less than 3 GB of RAM
Have a question about my Lem 10 (1x16) watch. I loaded some video files and the VCL app Mr. Ticks used in his latest video, into my apps folder.( I was going to install it when the watch came on line. These are the same files I loaded into my other Lem 10 (3/32) with no issues.)
I did a reboot and the watch went into a boot loop displaying the Lemfo logo for a few seconds and off and repeats. So I removed the back, disconnected the battery for over 30 minutes. Flashed the watch with the (1x16) firmware and the flashing showed it was successful.
I left the watch charging,on the computer for a bit because the battery was probably near dead. When I tried to restart the watch it is still in a loop now showing the battery symbol (red) for about 20 seconds and then the logo, screen black, battery, logo or in a loop. When the battery symbol displays the volt/amp meter shows the battery is taking .441A or about 1/2 amp then goes to zero when the logo displays and repeats but shows a charge each battery display. It has been connected to the charger for about 2 hours but still shows the same information.
Any ideas or suggestions?
Is it also getting really hot ?
Its very warm to the touch but not really hot.
Please, how can I receive and cancel phone calls by the watch, knowing that my phone is samsung note 10 plus
If you have wiiwatch installed remove it . Install this on watch
And install this on phone
When you pair watch and phone do it the normal way as you would any bluetooth device . Make sure in watch " watchdroid " is turned off in battery saver .
This will give you all the functions you need and more .
Calls are already received but calling is interrupted and does not work when Wi-Fi is on
What are you using to connect watch to phone ? .
