It is not the most beautiful i made, buy it works very good, i made a small wire tot the back and the strap and used some adhesiv alufolie, i think i am gonna try a metal strap in place of leather.
When you hold the watch in your hand make contact with the metal mount at the side of the camera, that’s a quick way tot try
To be honest . I thought this was a wind up ? There is no way i am doing that to my beautiful Lemfo Lem10
. Keep up the good work
That’s why i try a metal strap , i can remove this without any scratch, it is experimental, buy you can try the other solution, make contact with the metal mount and try to text
Is your watch performing so bad ? Although not perfect , after last update i am more than happy with mine
I was nog happy because texting was impossible, now it is working well, i have ordered a new one to see the difference. I am using wattsapp every day. I have also the microwear H5 and H7 and texting one those is very good,also when i use a stylus.
I just tried the lem10 with a Stylus and it works only on the top half of the screen, when i use my fingers the whole screen works so it is defenitly a grounding issue
I see that the new one is arrived in my country, when i have it i tell my expierience
Hello lovely people, I’m new to this forum so hello everyone. I got my watch from 2 days. Its great.
I wonder, is it any possible to could answer to sms or messenger on watch when connected via Bluetooth to mobile?
Search for watchdroid application on this forum…
Welcome !
Use these -
After installing do NOT update as you will lose features .
Thabk you so much but could you help me with connection. I installed app on both devices but can’t connect. What am I doing wrong?
Connect as you normally would between watch and phone . Dont use qr code . Disable watchdroid in watch in background cleaner . Thanks
Works perfect… Thank you so much… Love this watch… But battery is not as I expected… What’s your opinion?
Personally the battery on this watch is great .
Turn off google sync
Turn off pedometer
Use 3g instead of 4g
Use wifi only when needed
Let me know
Yes it helps a lot…
connected to mobile via Bluetooth so couple notifications,some fun and last about 10hours
Its my firs smartwatch… So how would you compare battery life to some Samsung etc?
And I have found on forum couple better watch faces but its still just few. Is there any place where I can find some? Could be free or some paid.
Thanks for being so helpful I got more fun with watch after your suggestions
Hard to compare with samsung as totally different watches . 10 hours not bad ? Try the square and rectangle faces on this forum . Dont forget the round ones work as well .
someone has the root process for this watch please share. thanks
How do you find heart rate sensor?
I done some exercises today and wanted compare to my polar heart monitor. And not working at all. All the way shows 60 80…when polar… 130…140 and more…
