Wise decision - flashing firmware is not for everyone and can be challenging ![]()
V1.1 added to the support thread:
I confirm that the lokmat and z40 versions loaded on my lemfo LEm 16 have reverse camera problem.
2 ota you uploaded one but what would the second one be?? Thanks for your help
do you have the two ota versions??
if you have the 2 version I can upload version 1.1 otherwise Iād better wait. I didnāt know there were 2 ota versions after version 1.1
news this morning they answered me from lemfo with an email.
apart from that it seems to me the same version that I have now but I tried to download it doesnāt let me download the firmware
I have only uploaded full versions.
Not OTA.
Itās just there if you want it.
But you need to use the unisoc flash tool. ![]()
One OTA will take you to the v1.3 and the next one with the camera fix has not been tested and released yet.
but there will be a new ota with camera accommodation?
today I tried to insert again the 1.3 version that lemfo sent me but nothing is the same as the one I had.
sorry if I only reply today but yesterday I had sent 21 messages and I was blocked
yesā¦@pablo11 said soon the manufacturers are releasing an over the air update for the Lem16 and lokmat Appllp 4 that will hopefully fix the camera issue as they are aware of this problemā¦so i assume this OTA firmware update will be Version 1.4
installed version 1.1 camera works fine. can you let me know when a stable ota 1.4 comes out?? thank you
No, we canāt. But when it does, weāll announce it here. Until then, youāre welcome to refrain from further inquiriesā¦
sorry if I disturbed you too much it was not my intention
1.4 has arrived!!!
the new update is worse. google play , maps , gps not working. lem 16 is getting very hot. video calls fixed the reverse screen but broke the others
Iām sure youāve already performed a factory reset? Because of course you know to do this before reporting bugs? ![]()
Joking aside - Iām sure you didnāt. I also installed it and everything works without problems. At least after a factory reset was performedā¦
must admit my lem 16 is getting hot aswell, and facebook messenger video reverse is fixed but now i am getting no audio during video callsā¦all permissions are allowed and yes i did a factory reset,tried uninstalling messenger and re-installing granting all permissions again and still getting no audio
version 1.4 I confirm that everything works except whatsapp Skype audio with Google assistent . try disabling google assistant
Bit of a bummer as i use google assistant for calls and messaging on my watchā¦better than fiddling with a tiny screen ,but thanks anyway, at least i know what to do if i do need to use video calling
Has anyone tried an older version of the Google Assistant app�
Iām thinking that the recent version of the app may not work as well with this google security patch of Android 11 or the play services app may need to be manually updated.
Because the Google Assistant app is not included in the firmware by default, it makes it very difficult to fix.
@Davide_Muratore are you familiar with getting a logcat�
Using ADB shell.
This is what is needed I guess
We are testing it now to try and pinpoint the issue.
If anyone can grab a logcat it would be very helpful.
no sorry i donāt even know what a logcat isā¦
I also wanted to ask you if the weather app could be updated by itself if old smartwatches updated by itself
9 posts were merged into an existing topic: Android 11 is here! Lokmat APPLLP 4 Pro and LEM16 Z40 models
