For these to work read our " how to array 100 " post . I updated it for A10 . You will need to modify faces manually . Thanks
Hello,
I read about the Google Calendar issue, I think that also the Google Translate doesnât run on the Lemfo LEM12 Pro.
Google translate should workâŚ
I will test it.
Google calendar cannot work because of the stock calendar app and the calendar storage provider sync app, which is not in the system like the older watches.
Many thanks, I had already tried the AVRP change to 1.6 but it didnât help. I changed the audio codec and it may have improved a bit but I havenât tested enough. Since it drops when you cover the face with your hand, it is apparent that the signal is coming more out of the glass and less out the metal sides of the watch in a somewhat directional way .This explains why I get drops riding a bike as the watch face points outwards and is on the other side of my arm. Btw, I have a soft bracelet and not a metal one. I am waiting for a Prime-2 and it will be interesting to see how the BT performs outward from a bigger screen. I assume that these are BT class 2 devices and I guess to really solve the problem, it will be with a class-1.5 implementation and a bigger battery to support it. Until thenâŚ
Many thanks, I managed to get all the interactive buttons to work with the new pkg and cls names except the Phone. I am not sure what pkg name to use. I tried âdialerâ, âphoneâ âtelephonyââŚbut none worked. The package name app gave the cls for all these as ânullâ so I tried to put nothing in the space, tried to delete the cls entry and also tried to put in ânullâ as the cls. I am tired of the trial and error novice approach. any suggestions?
try this:
Ordered one on Aliexpress, will get in hands about 30 days from today, fingers crossed.
Does this smartwatch is root capaeble ?
Root access on Android 10 is pointless.
We have it and published it.
But removed it because people didnât understand that root access on A10 is purely systemlessâŚ
Check it out on google
Just to confirmâŚI still have the problem with the stock alarm setting one hour ahead. I downloaded the google alarm clock and it also sets one hour ahead. So I guess the problem is with an internal clock address or array somewhere in A10?
Many thanks. All the interactive buttons on my clock face now work.
Have you used manual timezone and checked dst ?
Yeah, thatâs the way.
Check Timezone and DST⌠
Hello,
Iâve tested Translate again, this is what I get from logcat after it crashes, I never succeeded in getting it up and running:
--------- beginning of crash
11-25 23:52:59.933 6172 6172 E AndroidRuntime: FATAL EXCEPTION: main
11-25 23:52:59.933 6172 6172 E AndroidRuntime: Process: com.google.android.apps.translate, PID: 6172
11-25 23:52:59.933 6172 6172 E AndroidRuntime: java.lang.ClassCastException: android.widget.FrameLayout cannot be cast to com.google.android.libraries.material.aspectratio.FixedAspectRatioFrameLayout
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at com.google.android.libraries.material.accountswitcher.SelectedAccountHeader.d(PG:5)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at fgg.a(Unknown Source:51)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at kf.onApplyWindowInsets(PG:2)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.View.dispatchApplyWindowInsets(View.java:10528)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewGroup.dispatchApplyWindowInsets(ViewGroup.java:7266)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at kp.N(PG:2)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at androidx.drawerlayout.widget.DrawerLayout.onMeasure(PG:23)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.View.measure(View.java:24746)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:6903)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.widget.FrameLayout.onMeasure(FrameLayout.java:194)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.support.v7.widget.ContentFrameLayout.onMeasure(PG:23)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.widget.LinearLayout.measureChildBeforeLayout(LinearLayout.java:1552)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.widget.LinearLayout.measureVertical(LinearLayout.java:842)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.widget.LinearLayout.onMeasure(LinearLayout.java:721)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at com.android.internal.policy.DecorView.onMeasure(DecorView.java:742)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewRootImpl.performMeasure(ViewRootImpl.java:3135)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewRootImpl.measureHierarchy(ViewRootImpl.java:1903)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2203)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1791)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7867)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.Choreographer$CallbackRecord.run(Choreographer.java:967)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.Choreographer.doCallbacks(Choreographer.java:791)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.Choreographer.doFrame(Choreographer.java:726)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:952)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.os.Handler.handleCallback(Handler.java:883)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:100)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.os.Looper.loop(Looper.java:214)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:7386)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
11-25 23:52:59.933 6172 6172 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:980)
@none what do you think about this?
I think it is a google dependency. Maybe
The watch checked for firmware updates and successfully downlaoded ota and installed version 6 dated 202001102.
But now the watch overheats when charging and will not switch on at all. It is unusable, blank screen. Version 6 update seems to have "bricked " the watch.
Please any ideas on how to fix this?
Factory reset.
Always after an OTA update
V6 is fine
Thank you. Confirming I simply followed the instructions on the watch as it successfully completed the OTA firmware update to V6. Are there any options to unbrick the watch?
Press and hold power key for 30 seconds to force a boot and then factory reset
If this fails you can just flash the firmware manually
Thank you. Yes tried power button held, but failed. Meaning the watch did not turn on at all unfortunately.
