And what firmware version did you have before?
Z32-LEM12pro-V05_20201024
Ok, I will check the md5 hash.
So you flashed v06 using the firmware upgrade option in the flash tool?
Yes exactly. The firmware process went well, but the clock did not turn on.
@Alexcomrad Ok - until tomorrow you can go back to v05 and I will check for image consistency tomorrow morning - it’s almost midnight here. Sorry.
@Jinguel maybe an issue with the v06 file.
Did you have same problem?
If you have issue getting flash to start after v06 failure keep power button pressed while firmware is set to flash and you have clicked on the download button in SP tools.
When it tries to boot it will flash
Sorry, I didn’t think about the time zone.
No worries
Download is corrupt.
Two confirmed is enough
Thanks, I have already rolled back to v5
will it continue to boot if you do as it says and press the power button?
I doubt it.
Two people have confirmed exactly the same issue.
I am removing it until tomorrow.
Hello in this version of Android there is no clock app? with the stopwatch and countdown etc …, I can’t find it … Thanks
Hopefully the checksum will ensure it is ok.
Let me know.
Thank you Pablo 11! Now I’m at work and there is no way to download the firmware. I’ll download it at home and report the result.
The firmware was installed without any problems. Everything works! Thanks for the support!
Thank you Pablo 11!
Question: This will be my second time upgrading. Is there a way to back up your applications and once you flash the new firmware and start fresh, reinstall the apps with a batch process?
the 7.1.1 watches have also had that ability for quite some time now
Yes it same on all watches for the last 2 years.
