Wow thank you! I thought it was in settings. Can you delete my post that I asked the same one?
Done . All sorted
Guys, Mr Ticks has some discount vouchers for the LEM12.
I’ll ask him to pop in.
New firmware in top post
Hi gang. Got this from Banggood for 30 units while they last:
Newly released LEMFO LEM12 PRO with Android 10! Use this link to buy: https://bit.ly/3ollyYb (Exciting news! I’ve got you a 25% discount coupon valid 10/22/2020 - 11/30/2020 Use Coupon code: BGSTL12P - valid for 1st 30 units ONLY)
Hope this helps for those of you wanting to give it a test drive.
Thanks Mr T
Thanks Mr T
Thanks!
(It shows now EUR195,44)
There were only 30 available for this price.
Not here, thanks @lrr
Hi, first post here, I am quite happy with the watch, still trying to get in terms of how everything works.
How do I disable the pedometer and the fitness app? I am trying to get a bit more battery life.
Might be simple but I can’t find out how to set custom ringtone?
Is there a tutorial on how to make watchfaces?
This is not possible with fitness . You can force stop but not recommended . However install this
Install and goto " sync " . Turn off " sync " . This will save a lot of battery
. This is usually visible for google but has been hidden in android 10 .
Hi all - please test the new v06 firmware in the top post and let me know how it goes.
Take the tools package as well because it is packed with 7zip
Google sync is disabled on this watch at the moment (and has been all along) - pending further tests
Did you use firmware upgrade option?
If not then you will have problems
By the way, using a metal strap looks nice but you will draw more battery because the strap interferes with Wi-Fi and cellular signal
Do NOT use format all +download !!!
Thanks, but I didn’t notice the difference.
Yes, I used the option to update the firmware
