No, sales of this watch have not yet ceased. there will also be firmware updates. Have a little patience.
Many thanks for your answer. Have a great week end.
Received my LEM12 Pro to replace my Genesisā¦wow super impressed with the build quality and the watch overall so far.
Anyway. Iām wondering is there a way to integrate apps like watch droid into the UI so they can be accessed through gestures. Eg, swiping right from the watch face takes you through various functions, could watch droid be added to the list of functions when swiping right
The stock launcher does not support widgets, but you can install another launcher.
Do you have a procedure on how to remove wiiwatch with āminimal ADB and fastbootā? I am able to connect to the watch with minimal ADB, but from there, I donāt know what to do (I am not familiar with Android development tools)!
Cannot remove a system app in A10.
It will just re appear after reboot.
Unless you use magisk manager to create a system-less image. But this is also not really a good idea.
Why do you want to remove it?
Just donāt use it and it doesnāt interfere with anything elseā¦
Sorry @pablo11 , but you are wrong. But let us talk abou it before I post a tutorial.
Ok cool.
Cheers.
My problem is it wonāt allow me to put in the APN settings so I can use data via my sim.
The main reason is that I donāt like to have a lot of unused icon in my app drawer. Wiiwatch was an example of app that I want to remove, but I also want to remove other minimalist app like the file manager, calendar, web browser (I prefer Firefox), etc.
@tobor I just posted a little tutorial how to delete Apps:
-How to delete installed Apps on Android 10
Thank for the great tutorial, really appreciated!
(I was stuck at step 9 before your tutorial!)
You are welcome.
Ok so Iām struggling to get through the day with my LEM12 Proās battery.
I am basically only running watch droid at the moment with stock launcher & a kavosis watch face. No Sim, wifi off, GPS off, 50% brightness, set to take heart rate every 2hours for 2mins, raise to wake set for 5seconds etc.
Have just seen that there was a factory install do app āblazing with coloursā that may have been causing parasitic battery drain, so have disabled that.
Am I missing anything?
So how many actual hours a day are you getting ? I have this watch and as you are using it , it should get longer .
Did you factory reset as soon as out of the box first . Normally cures everything
Iām getting pretty close to the projected hours in the graph above, so around 14hrs. Yes, when I received the watch I ensured it was full charged after unboxing and then I did a factory reset.
14hrs isnt bad really especially if you get tons of notifications
Ok
Iāll continue to evaluate. Itās definitely worse than my previous Genesis.
Now that does surprise me .
Just out of curiosity what does it show, below that screen, what is the battery usage, at the end of the 14 hours?
