There is a new firmware coming which is more Google friendly.
I’ll let you know when it is available
Thank you
Thank you
It depends on the solution provider when it is released.
But yes I will let everyone know
Is there a flashing tools for Windows 10 Pro? All my systems are Windows 10
I will give it to you.
One minute
The driver installer can be run in Windows and then reboot.
Done
Thank you Pablo.
Just a bit of feed back. I had network issues downloading the flash tools and Firmware from Google. It kept giving me network issues. I didn’t bother resuming. I just kept cancelling it, and tried to download it again. I eventually downloaded it. Not sure what’s going on there.
Anyways I tried to follow the PDF tutorial that was posted here on this forum and use the power bank. I tried many times but the flash tool wouldn’t detect my watch.
So I tried instead the usb direct cable to watch and that worked well and fast.
In the Flash tool software I selected the Firmware Upgrade option.
I must have a faulty Power Bank??? I just got it last week.
What is your location in the world?
Many people have downloaded the same package with no issues at all…?
Its all over this forum
You should use a direct connection with the cable to the watch.
Don’t try to flash using the dock… It is unreliable
Pablo, I’m from Melbourne Australia.
Pablo it could be my router/firewall, I’ve locked it down very tightly recently. I need to check
I am in New South Wales.
So yes, I suspect you are right
that sounds weird, but one certain way to fix it is by flashing the firmware from the top post
Agreed.
I have not heard this one before but it could be lost in translation.?
Yeah it is the firewall. I enabled all these DOS defense: SYN, UDP, ICMP flood defense. I disabled it. The downloads are now working well
There’s nothing wrong with my watch. I just wanted to see if I could flash it.
Flashed it, boot it up, then reset. Works well ![]()
I’m just poking around the hood to see how it all works. ![]()
It was in response to an earlier post by @Marek_Małecki
PS I will try to connect to a hidden network from my prime 2 (which is also android 10) when I get back to Grimstad
Wiiwatch assistant on watch does not work in Turkish. Connect phone app crashes.
Just reporting I tested my Tronsmart Spunky Beats with the LEM12 PRO(stock settings) on bluetooth.
Works behind a plaster wall 5 meters. Works with hand covering the LEM12 PRO. Works just as well as my Samsung Galaxy Buds+. I love this watch.
It will stay alive! succes! Thank You very much for advice:full_moon_with_face:
Is it possible for the default MP3 player to have a replay button please, may be even a playlist please if possible??
Thank you
Been listening to music with my Logitech G560 Bluetooth PC speakers, it’s awesome.
Far less trouble to install a different music player.
Getting the changes implemented in a standard MTK app is very difficult, to say the least.
