Happy Mew Year, Pablo always intrigued to read your messages.
I received seemingly new LEM12 Pro from Aliexpress Lemfo official partner.
However it boots into Arabic & is Pattern Locked, apparently set by someone /used.
Does any one know if watch supports booting into recovery to reset like a mobile using hardware buttons or can help describe to flash in detail/steps as iām new to it. (or flashing)
Hi . Thats terrible you have been sent a used watch ? However should you decide to flash it that will fix your problem . We have a youtube section at the top of our main page . Have a look through it .
Here are the tools you need
Here is a tutorial for another watch model but works the same
The firmware you require is at the top of this thread
If you need anymore help let me know
All you have to do is asking a refund !
Thank you,
Iāll look into it & give it a try later & also wait to hear from the supplier.
Yes true, that is indeed my last planned option but just thought if there were quicker fixes from experienced users/Lemfo as it seems new/clean with plastic film still on (perhaps a returned item, somebody might have just played around).
Iāve asked the seller & am awaiting a solution plus not closed the case with Aliexpress & my credit card company as a last resort.
However, Returning takes extra time & effort esp in these times from UK (Brexit -> holidays -> cross border transport logjam).
So I thought the helpful community here will come to my aid
If it appears to be new and unworn - it is very likely that factory testing of languages was done and they did not reset the watch before sending it to you.
If you have any doubts at all then you should return it immediately as @christ says.
In my opinionā¦
I can also confirm the default weather app is not working. Just shows a constant 5 pulsating bars trying to load the app in an infinite loop. Using latest build version 6 (FDR performed), GPS on with all permissions granted to the app, language English (United States), date and time - tried every combination under Date and time with no luck. I will keep fiddling with it but Iām guessing its a software issue.
Hello, guys! I have a problem with my Lem 12 pro! It turns on, the sim card works (I can answer calls), it works in power-saving mode and itās ALL!!! I canāt go on and no attempts to reset including turning off the battery help. I can access the storage from my computer.
Do you have any idea what you can do?
to get out of power-saving mode mode just longpress the power button, scroll down and press āPower Saveā
It looks like the Android has been removed!
It hapened when I was pressing lower buton to go back.
The metal strap is really good. Wifi and Bluetooth works well for me. It looks good and very easy to put on the watch on my arm
Is anyone here able to install and go through the setup of the Android Auto app?
Hello Guys,
I am trying to connect my watch to my wifi router. Iām using hidden wifi 2.4Ghz and 5Ghz on my wifi router. Itās not connecting. Anyone else get this issue? Is it a bug?
Try switching to the device MAC address instead of using random
If there is any LEM12 PRO developers here that can get this LEM12 PRO to fully support Android Auto app by Google. I would be so grateful if you guys can make this happen.
At the moment the Android Auto App crashes during setup
Thank you
Iām using the Samsung Galaxy Buds+, not the live. It works really well here, over 5 meters and behind a plaster wall. Covered the watch with my hand from a good distance, still works well. I also dance with the watch, no issues here, again Iām using a different ear buds to yours. So I understand, itās different
No good. Still doesnāt connect to a hidden wifi.
It connects to normal wifi, just not hidden wifi
There is a new firmware coming which is more Google friendly.
Iāll let you know when it is available
Strange, I must admit that I have never tried to do this
