I’m having some issues with Bluetooth scan/pair, I have and Bluetooth that doesn’t pair directly with the device but with an app that do readings in the background, somehow with this smartwatch it won’t occur, the reason I don know, maybe is something with location permissions or android 10, as I know lem10(android 7.1.1) can do that. It possible to flash Lem12 firmware on Lem12 pro or other fix ?
Its really sad because its the only reason I bought it.
Go to settings- apps and notifications- special app access. Enable unrestricted data access for the app you are talking about.
Also go to the Optimization app, CleanTask, click the list with apps and make sure that your app is switched off. Else it will be killed by battery optimization when running in the background.
I really appreciate your help, apparently, it has improved, the watch is able to maintain connections in the background. =)
Any body got TWRP Recovery working for this LEM12 Pro A10 watch? The LEM12 already got TWRP.
We have but we pulled it because it is Android 10 and system-less root is not understood by users very well.
It is very limited with what can be done because of Android 10 verity.
For example, you cannot flash anything because of the encryption and DM verity.
Re-listed here:
well, the imei was blocked.
Thanks to KOMINFO regulations, all the unregistered imei in indonesia which not connected to any network before april 18 this year will be blocked.
Wow… That’s shit
Do you have any more information about areas affected by this?
Just how many people would be affected?
it’s government issue to counter black market illegal phones.
so ALL of unregistered imei will be blocked in indonesia (remember my LEM T blocked imei?).
but changing imei to your own old phone is not an issue. since you legally “own” that imei and old phone.
I understand.
Lemfo has already begun to stop shipping to some places due to the restrictions.
Do you have any information about affected countries?
It will be very useful information for many people.
as for other countries. I suppose my knowledge as far as yours or less.
since I mostly only play in this site.
but luckily any chinese based SoC can be “tempered” as the users see fit. like the imei. since the tools available online.
the only things left just give them detailed instructions with prerequisite having unused old phone.
well at least that is not illegal in indonesia. dunno about others.
cheers
Iran and Turkey are subject to similar regulations as far as I know.
I will gather the relevant information tomorrow and make a public announcement.
Going to sleep now, but thank you for your info.
you are welcome. glad to be helpful for our FAW community
Hello, and thank you all for the great info on this forum. I received my Lemfo 12 Pro and inserted a sim card from Freedom Pop which is a reseller of AT&T. The sim requires manually adding an APN (fp.com.attz). I previously had a Kospet Optimus pro (android 7.1) and used the same version sim and manually adding the APN worked perfectly. With the new FP sim inserted the Lemfo 12 pro under mobile network it shows AT&T and going to Access Point Names there is no option to add an APN manually. It has listed ATT Nxtgenphone with no other options. Is there a limitation within Android 10 that will not allow adding manual APN’s? I have not done an FDR yet but was curious if anyone else had an issue adding an APN first
You can use the app “settings search”:
-https://drive.google.com/file/d/1_6Mghp_uVJ2lGsN9FTctLS0PzCxy_VXE/view?usp=drivesdk
Sounds good I will give it a try
just got my Lem 12 pro seems to be working properly. Are there any alrod watchfaces that can harm the watch ? Are there any other A10 watchfaces available yet ???
Can anyone confirm that the watchbands are 20 mm couldnt find any info on Lemfo’s website ?
my first impressions are great smooth interface great sound …
Does anyone with the LEM12 Pro have the option to add an APN under Mobile networks: APN names? If the sim does not come pre configured I’m not sure there is any way to manually add an APN name. Tried the settings search the moderator suggested and it just brings you to the APN Names menu which is there is no option to ADD. Not sure if its a limitation with the watch and android 10 or the Sim itself. Would be grateful for any help. May end up having to send the watch back if it can’t be activated.
We have no relationship with the watch face designer you mentioned. Sorry.
However, I can’t see how a watch face would “harm” the watch…
The worst that could happen is the launcher might lock up and a flash would fix that. Or a few adb commands if you have enabled USB debugging…
There are no differences between A10 and A7.1.1 when it comes to watchfaces.
Whether the launcher supports all the functions is always a question.
But again, no more than the A7.1.1 watches.
Anyone trying to activate there watch using an AT&T sim requiring an APN edit is out of luck with Android 10. Who ever brought android 10 to these watches left out some major settings capabilities that were present in the previous android 7.1 versions. I have been trying to edit/Add an APN with an AT&T sim and all android phones have a “Add APN” or + under the APN names menu - we do not with these watches. If you have a sim such as AT&T that is used by an MVNO you will get one APN option called “Nxtgenphone”. All options will be greyed out and can not be edited. With a real android phone or an older watch you just tap the “add APN” icon and create your own entry. This setting has been left out in Android 10 watches - anyone with this type of sim will never be able to activate there watch on the network. I can take the same sim in my phone and use the “add APN” icon and it works flawlessly. I’m not sure Lemfo or Kospet is aware of this limitation with there watches. I would caution anyone who uses an MVNO that requires an APN edit - without an “add” option they will not be able to be activated.
