What the benefits and deficits of flashing on a Lem T: Rooted Lem T firmware, rooted Ticwris firmware, or rooted Rufus Cuff firmware?
pablo11, you are answering talwinter?
The reply-to icon in Pabloās post indicates so:
I did not see that, thanks.
hello .im new in the group.thanks for accepting me.i want to put the lemfo lem t in the shell of the old motorola razr v3 but i need for space and measure to move the 2 antenna.i saw on youtube you can put 2wires like antenna witout using the original or using the wire like extension for the original.i will have to use it without the back cover so i will have to extend also the charging part of it with 4wires for the plug of magnetic pin.can someone expert in hardwere help meļ¼i still dont have the watch will arrive from aliexpres.thank you
I think YouTube and Google is going to be your best choice for finding information like this.
It is not too difficult but due to the construction design of the rear cover it will most likely ruin the device.
unlucky i didnt find enough info nowere ,that why im asking here .but thanks for the advise ,ill be supercarefull.regards
Hi Iām new here but I have found out that their are no antennas in the bands. The bands are removable, however take caution as the antennas are like small clips that kinda I intertwined with the mounting screws. It should fit nicely within a moto razor.
Can you post the pic of the battery connection. I got a brickā¦
The app folder is emptyā¦
Now that other watches with Android 10 coming available, is there any chance one of them could be ported to LEM T? Or is the hardware insufficient? Maybe you know, @pablo11?
No, this wonāt happen. Sorry.
@G1NT0N1C is right about existing devices.
However, the future may hold a different story.
I am uncertain yet but I know that Kospet is working on a product but the OS is not yet decided
Is the hardware to same as the LEM T?
No, it isnāt. Thatās the problem.
Hope my LEMT holds out until then⦠It is one of the very first ones from Sept 2019.
Apart from the rear case cracking issue, its been fantastic.
Upgraded firmware to Ticwis.
My wish is for a similar sized device, with :-
- Improved Screen technology, but same size.
- Later version of Android
- Dual camera function.
- Easily removable bands.
Would my wishes be beyond expectations?
bonjour well for bands there watches on sale with paracorde multifunctional buckles and compass on strap and thermometer. yes i k now only for men or girls in the SPACE FORCEā¦yeah.
andrew ps foldable watches would nice as well, thanks lads and pablo for the sight.
Hey. I flash ROM Lemfo Lem T, and Ticwris Max on my watch. Lemfo ROM on the CPU had 1GHz, and Ticwris ROM 1,28GHz. As far as I know, the CPU overclock is in the Boot.img file. HOW do you add more MHz for example (1.5GHz, 1.8.Ghz, 2GHz) to work faster? Sorry for my English. I am use translate
@Pixie
The reason the clock speed is lower on the different firmware is to save battery.
You can only charge frequency settings do this if you have root access and a kernel control app.
But I can tell you this, if you overclock the CPU or mess about with it you will probably kill the watch due to heat issues.
You are safer just using the firmware that has the higher frequency and set it to performance mode.
Go to Settings / Optimisation / Operation Mode and set it.
But you will use a lot more battery and it will get hot.
On top of all this - I can almost guarantee that it will make absolutely no difference for you.
Bottom line is I donāt recommend you change anything.
Hi. Where I can download Clean Android 7.1 (AOSP) or possibly build it?
