yes, you’ll do it from the pc and connect the phone
Is that a good idea, given the hardware?
The new MAX S is coming with a 2.4 screen and A7.1.1.
But soon after that there are plans to upgrade it to A10.
The LEM T might get official update or the Openwatch team may release a version for it.
We will have to wait and see.
Interesting.
will it based on MT6739 C10 board or MT6762 board?
shame with reduced size means less battery capacity as well. hope android 10 will make it worth the upgrade.
Work is underway to release Android 10 for the M6739 soc.
The OpenWatch guys have done excellent work in this space as you know, and this has inspired the main solution providers to do the same.
C10 and C7S boards.
3gb ram and 32gb storage.
As for the Wiitee official release - It should be ready early next year, all going well.
Should not be too difficult to retro fit to most suitable A7.1 devices.
This is still a way off yet though and as you know - anything can happen
yes I agree. considering MT6739 chip is not really well received in the market these year (2018-2019) and samsung release of galaxy A01 core this year (2020) in Indonesia using Android 10 go. In a sense I believe many MT6739 driver were updated to compatible with Android 10 and thus it will smoothly upgrade any of these devices, especially from oem like wiitee since they have access to mediatek source.
Well, let’s see what happens.
It’s definitely interesting
Hi Pablo,
Do you have any other pic/tech info about the future MAX S?
thanks,
Nicolas
Maybe you all missed this?
few thought about the rectangular watch based firmware (LEMT, MAX) after using it so far:
- default system orientation is for potrait apps are making camera positioned below the screen. however this configuration is override but only in stock camera. which make any apps using their own camera capture mode (e.g whatsapp, instagram) still have the same orientation as system and pressing the camera button will possess a challenge since it near the camera lens.
- The firmware is still using 32bit firmware, which rather obselete considering MT6739 64bit capability.
- Face unlock features using standalone screen lock app (in ticwris firmware) which cause most dialer app other than stock must open the lock first before can accept the call.
- Not working accelerometer as screen tilt sensor. this also makes problem (1) a little bit problematic since it needs manually adjust orientation using app.
So what I was trying to say is for newer watches firmware (not recommended existing ones, since basically no benefit for wiitee or any oems out there for that) with rectangular screen especially and 3/32 or more configuration to using accelerometer as screen tilt sensor in 4 modes (90, 180, 270, 360). sound simple but its usefulness will remarkable.
Also using 64bit firmware will make the choice for using cortex A53 based SoC over cortex A7 will show it’s worth. since A53 is more power hungry vs A7 and 32bit firmware will not make A53 shine at all from battery perspective. it even perform worse in terms of battery which one of the most concerning situation for us FAW users.
I put some references how both A53 vs A7 perform as close as possible (both in 32bit) in comparison here
Sorry for the long post. I hope this will reach oems out there
Apparently my initial reply didn’t go through. If this is redundant, please forgive me. I just wanted to give a shout out to “noidremained” for this post, as this procedure was my ultimate goal! This procedure bypasses one from having to use the SP Flash Tool and is really simple and fast. Just make sure to follow the simple instructions as prompted.
I cannot go without giving recognition to “pablo11” as he too gives great insight on this subject. I intend to continue reading because like “Lira_En_la_Red” I too get the error after trying to install the update that is immediately available after booting this firmware. Again thanks to all that shed insight on this subject because for me at least, it will forever remain relevant.
Hi there, do you know if the new Ticwris MAX-S has a better speaker or mic…on the LemT the sound is really poor and muffled even after installed the Ticwris system. Thx, i am considering to buy the new S.
Not yet, we are waiting for them
Ok thx. I did order it on Ali…
We have a separate thread for the MAX S.
Please keep on track guys.
It started sales on Monday this week.
Yesterday.
Hi how do u turn mobile data on pls
Already replied to this question
Yes u have thankyou for ur quick response i have msg u back on other thread i dont see option for celluar on my ticwris watch
