the google pay app doesn’t work? It runs fine on my bakeey a4. contactless payments won’t work though
@noidremained it seems to be working for some, depending on their location.
So just to be safe, we say that it is not supported yet.
@Moderators… Is source for Kospet Prime firmware available? I am thinking of making changes to the firmware as per my own requirments, if at all possible.
Unfortunately it is not open source.
So no, it is not available.
Cheers.
Thats Ok. But can we write an app for this smartwatch? Does standard mobile app works fine on smartwatch too?
Unfortunately no.
You can use magisk modules but the system/super image is not possible to edit.
What do you need to add?
I wanted to add small functionalities like weather auto-update to the standard launcher ( i do not want to use unversal launcher). Probably an app could do it.
That issue is already addressed in the next firmware that will be released.
if they are releasing a new update, how about adding a functioning download app? the bundled one doesn’t allow you to change folders (limited to “documents”) and open select anything but images and such.
On the KP2, it’s fully working. Reason I wanted a working “download” apps is due to some apps using the poor downloads apk to open files. (ghostracer trying to open gpx files is impossible in KP1)
Yes I understand but it is a signature app and I doubt it will be removed.
However, it does not mean that it cannot be fixed.
I’ll see what I can do.
Instead of fixing the old download apk, can’t it be replaced by the one on the kp2?
Sorry but it’s end of life @R_Sauvalle
I doubt they will invest in this anymore.
And I apologise,
I thought I was in the Prime 2 thread…
Going bloody crazy
Where will I find this Download only mode and flash tool and where can I find the file to flash??
You will always find the newest firmware at the first post in the firmware threads, such as this one.
Flashing tutorial here:
https://discourse.fullandroidwatch.org/t/ticwris-max-s-arrived-today/60899/54
Flashing tools:
is this still true for the v2.6? @Vaho_Mat @pablo11 ? I’m going to try to fix missing shared libraries from google maps with adb. Need root for this.
EDIT: found v2.3 had patched boot img and recovery.
There is an app “Weather on raise” that was posted here. I downloaded it and works perfectly.
I have a problem. After installing the system update, the times do not start. Can anyone suggest a solution to the problem?
Prime 2 system update?
Can you explain a bit more please?
Do you mean that you flashed the firmware?
You need to show us what you installed and how you did it…
You have a KOSPET PRIME 2 watch?
I have cospet prime. I went into settings and searched for a wireless update. After the update, watch started and worked. I went into the settings again and checked for an even newer update. Then I inserted a newer update. I performed this procedure again, but after the third update, the times did not start. It is displayed on the screen that the red battery is then loaded, writes Kospet, but then does not start. The red battery and the inscription kospet alternate. Charging the watch does not help, the charger works. What will be your thoughts on solving this problem?
