Kospet Prime firmware Updated 18 Sept 2020
I suspect that you have an original Kospet Prime.
Not a Prime 2.
There are no system updates for the Prime 2.
I also suspect that you should have factory reset before you selected any further updates.
I have an original Kospet Prime.
but before the update I did not reset to factory settings. It’s just that the last update probably caused a system failure and it didn’t work properly. What do you advise to do in this case?
I think you’ll have to flash the firmware. Here is the latest version:
-KOSPET_PRIME_v2.6_B_20200908.7z - Google Drive
Here you find a tutorial how to do it:
-Flashing Tutorial.pdf - Google Drive
And here are the needed tools:
-Flashing Tools.zip - Google Drive
Yep, this is the way to go.
You will need a Windows pc or laptop to do this.
But it should work :+1:
@Максим_Π–Π΅Π»Ρ”Π·Π½ΠΈΠΉ are you sure that you charged it long enough?
Thank you, I apologized, but the problem remained. Maybe you have another version of the firmware?
yes more than 4 years
Of course, but it won’t solve your problem. Please try again and choose β€œfirmware update” instead of β€œdownload only”.
How I can choose β€œfirmware update” instead of β€œdownload only”?
It’s an option in the flashtool.
thanks found
Did it solved your problem?
Unfortunately no. I am very grateful to you for your help. Π†f you have another version of the firmware received. maybe something with the battery, but I doubt that everything coincided
In this post you find most of the other versions. But, once again- if the latest version is not working the others won’t, too.
-Kospet Prime firmware Updated 18 Sept 2020
can you force a bootloop? If possible, do so and wait for the battery to drain completely. Then use the β€œfirmware update” option again and connect the watch without charging it first. Usually this works in any case.
I will try. I am very grateful for your help
You won’t believe it, but I put version 2.3 and everything worked. I put 2.6 several times and downloaded it from the official site and nothing works. And with the wireless update for 2.6 wach hung. I don’t know why, but on version 2.6 my wach definitely do not work. I am very grateful to you for your help !!!
I’m glad you’ve sorted it out. I’m sure you should be able to update to 2.6b now. You should give a try…:wink:
I knew I’d heard of something like that before
Ok. Maybe I’m wrong. Confuseing…
