Ah I see.
Hmm, I don’t know if it is serious enough for them to make a new version for.
Are you saying that it was working in v2.3?
I hadn’t paid attention to other version 2.3b the 12 hour defect and the launcher problem is inconvenient for the use of the watch .
there were some faults not mentioned by users corrected, I hope they will correct that too
Can you test v2.3 and let me know what you think?
For both issues you have mentioned.
Because I believe they were already there in 2.3.
for the application launcher is was random the problem
I will install version 2.3 for test
Thanks.
I will be interested
there is no screensaver for version 2.3b .
the time for the screensaver and a new option for 2.4b .
about the problem please and told them to change the green color and put a blue color that will be more consistent with the kospet prime brand please
Ok, I will look into it but I can’t see this as being important.
The launcher issue might be though.
That launcher is designed to roll application into the centre of the screen by using your finger.
Once it is near the centre you can click on it.
If this is broken it is important - even though I think it should be scrapped…lol
I will flash v2.4 and take a look.
About the screen saver face - have you looked at the settings for it?
you are right, the launcher problem and more important than the standby problem .
yes I looked at the parameters there is no setting for 24 hour of standby charge mode.
a precision the standby mode hour appears once you have plug into the charge dock
Do you flash using firmware upgrade or download only?
I only use the firmware download that you share
I think the launcher problem comes from the number of applications . i install 25 applications
No…
That’s not what I mean.
I mean, whan you flash with SP flash tool - do you flash using firmware upgrade or download only option in the flash tool?
download only
Then you MUST make factory reset otherwise system temp files are left in hidden directories.
Test again after factory reset.
For the launcher problem I mean.
Of course, the other problem is that you seem to be using the watch like a tablet or PC.
I just cannot understand why someone would need to install 25 + apps on their watch
On top of the stock apps this is amazing
I always do a termination of the settings. I bought my watch to replace my smartphone . i have not problems with the launcher the version 2.3b ,
Oh really?
So the launcher is ok on v2.3?
And you are telling me that you make a full factory reset after flashing v2.4?
yes full factory reset after flashing, the problem is random whit the other version 2.3b with left right movement launcher
I just flashed 2.4 using firmware upgrade option in the flash tool (generally I always do unless firmware is from a different watch).
The bubble launcher is rock solid.
No problem at all.
Maybe 25 apps is just too much for it?
By the way, where is the option for the lock screen watch face?
I don’t see it… But I also don’t have security enabled.
the problem is random to launch it. for the hour :
connect the watch with the charger and standby mode is activated
