@droidtrix and @pablo11 - this is the first I’ve heard of this. Thanks, I look to learn something new everyday and this is definitely a TIL:-)
I just talked to the designer. It really does, but it doesn’t work yet. This is only B (BETA) version. It will only work in the T version.
2.3B OTA downloading
I always the problem with the battery circle custom small deception apart from that I am happy with the new version v2.3_b_20200706 Google play works correctly.
Yes it’s good.
The display adjustment shortcut cut having better increment is a bonus.
I’m still testing battery.
The last version (even though it had the Google problem) was amazing.
Incredible battery life…
Fingers crossed this one is just as good
Hi, Can anyone answer my question!
What is the latest android security patch level of this firmware?
Thank you
The exclamation mark at the end of the first sentence is a typo, I guess? If not, you could still post in capital letters. This would add a little more emphasis to your question.
Hello Pablo, what’s The new display adjustment shortcut cut ? do you have a screen ? please, thank you.
On 2.0b, i have all time the icon power saver disapear and never come back.
I was of course joking about the Holographic display as were others before my post joking about new features in version 3. I think we are still a quite a ways off from having holographic displays as are often seen in newer science fiction movies. Would sure be nice though!
I don’t know why it is important to you ?
You don’t have the watch ?
If you did you would know already.
These are not Google certified devices so will not get security patches.
They do not have the info in the “About” section in settings and so no one answered you.
Where the WiFi BT and Cell data shortcuts are - if you swipe down on the main screen.
The brightness setting shortcut now has four steps rather than three.
Could have direct access to the circle / square application without having to press a button for a long time or with a shortcut in the next firmware (3.0b)? because I often have to use this function
How do you think there will ever be a version 3.0?
You do realise that version 2.3b is quite likely to be the final version right ?
Why do you talk about a version 3.0 ?
This is why it is making people laugh…me included.
Like the Hope model - there comes a time when the product has gone as far as it can go.
There is little to no chance of there ever being another version but if there was it would be 2.5.
The only way to achieve what you are asking is possibly with a button remapping tool.
But I’m only speculating.
I say that with humor because there is very little change from one fimrware to another from 1.5b to 2.3b for example.
Ok. At least we understand now
What would be the command in clockskin to activate square/circle app ?
There is no such command.
The launcher is whitelisted from that.
So switching from round toe square will not affect the faces.
Hi fiocco,
I recommend an app for your need,
It is ~ swiftly-switch-pro~
You can find & download it by Google!
Hello Rogerlo, I have already tried it but it is too complicated to use.
The action is called ‘System optimization’ on apps.
