New version 2.1b is coming OTA this morning. now is downloading
Yep.
For 3+32 or 1+16 version of the Prime?
Should be 3+32
I just checked my PRIME(3G+32G) , there is indeed a new version of the updated firmware !(…It should be V2.1_B)
Yep - I’ll upload the full version but there was no rush due to the OTA.
yes for 3+32
What does the upgrade give us. That’s different from V2.0
a new icon for a look screen, more fluidity, and a better battery life, is what i observed until now
I have updated my watch V2.1_B. my custom dial and buggy the gauge of battery which feser a circle and buggy thank you kospet (I have the same dial in 30 colors to modify I am not happy
This seems to be all about the launcher, Stock or UL…
In this case, only a small adjustment in the clockskin xml is necessary to fix it.
I’m actually wondering if people are performing a factory reset after the update
If not then there is always a possibility of bad behaviour.
only a small adjustment in the clockskin xml ?
i used Watch Face Designer need save in another format ?
look at this:
I watched thank you.
I save all my projects with the option (export twiked clockskin) and I check the box (Generate a img-clock_previw.png file + Reposition the battery information) .
the file and buggy today .
I am a little lost
Full flash version of v2.1b added to top post.
No change log unfortunately - yet.
after each update i do a factory reset, i followed tips all previous posts
Excellent… It’s good practice
I love this forum it is enriching to read all the comments, I learn from all the comments
I did a lot of tests I can’t solve my problem. my personalized Round Display not works more on the new v2.1 _B … I returned to the version v1.8 _B I like my personalized Round Display . I hope the bug will be corrected
