You need to tell me what array value is that is causing the problem.
As far as we are aware only array type 13 is a problem…
the bug and for array type> 14 ( this is a circle battery gauge )
Your battery has been moved 200 to the left i believe . This can be moved back in the .xml file . Have a look under the clockskin .xml under array 14 x and y . When altered save it . If you have universal launcher installed the battery would work with no adjustment as it works the same as WFD .
Hello my friend, try to press the air pressure release button at the back of the watch… It helps me. After I finish my running session, I use to put my Prime under the faucet and I wash it (only with water, no chemicals or soap). Sometimes the speakers capture air and the sound isn’ t too loud or the speakers make noise, when I playback a song. So I have to press this little button and problem is gone.
Thank you, that we are now getting more regular OTA updates. Minor or major changes, it feels like we are taken care of, which is a nice user experience
Thank you for your message.
I am using the original launcher.
you are right i changed the value ( x 400 ) in WFD.
. a big thank-you .
@floon Just curious…
Have you tried switching from round to square settings in the power menu?
Just switch it on and off to see what happens?
The round white symbol at the top of the photo.
When the new version of WFD is released this will not be a problem. Trust me it works fine
I just tested. the bug is still there. to solve the problem I have to modify the battery circle by 200 to the right in WFD.
the new version will be welcome
I have version 0.14.1. setup pc win 10
Its works well . Myself and @G1NT0N1C have tested it
Yes, at the moment you have to correct it manually. But I’m sure Marco will solve this with the next version.
I just saw that the temperature of my dial and more in ( C ) celsius he is in ( F ) fahrenheit
If you are talking about Universal Launcher, you can change this in the settings:
Search weather temperature unit.
I am using the original kospet launcher.
the original kospet dial and more in celsius as well.
Strange, i’m on 2.1 too and mine is °C, as usual. Ok, goto settings- date and time. Check the timezone.
Did you perform a factory reset after updating?
I’ve only had my Prime one day but didn’t know about that option. Fixes not being able to hit = in my calculator app ![]()
New here but not new to Android phones and watches and rooting / flashing.
I downloaded the 1.5b and 2.1b firmwares for the Prime. It looks like the 1.5b has the rooted boot and TWRP but not the 2.1b. I’m trying to figure the best way to have root and TWRP and get up to the 2.1b update while keeping root and TWRP. Suggestions? TIA
I just reset my watch again and it came back to Celsius
Good to hear mate.
