Hi . Yes its safe to update and yes its official . Please note this forum has a search function that is usefull .
Be carefull as you havent done this before .
Thanks a lot Dr_Andy_Vishnu, I appreciate it!!!
@fiocco Rooting process and flashing twrp was perfectly explained in this post by @pablo11
Just note that the âpatched bootâ he is referring to is named âmagisk patchedâ in the files list, or something similar
Your very welcome
Thanks a lot you all!! I hope donât break anything
Some questions before update firmware:
Should I install universal launcher before update smartwatch kospet prime firmware?
Video shows SP_Flash_Tool_exe_Windows_v5.1824_Win while Flashing Tutorial has
SP_Flash_Tool_exe_Windows_v5.1804.00.001, will it work anyway or should I download 1824 version? Where can I find it?
Iâm using windows 10 and MTK_USB_Driver_exe_v1.1032.0 works up to windows 7, will be compatible?
Thanks and sorry again for these noobs questions!!
Hi, I followed this tutorial for install mtk driver in Win 10.
thks
https://discourse.fullandroidwatch.org/t/kospet-prime-firmware/50679/136?u=malex
Thanks a lot!! I was very worried because I donât want mistakes here, thanks for your time and advice.
A virtual beer for you!!
Thanks a lot, I will do it, I had a tutorial from Dr_Andy_Vishnu that itâs fine but when I saw different driver version I want to be sure of what I was doing, I donât want to âbrickâ (if itâs called so) my smartwatch so thank you too for your time and advice.
Another virtual beer for you!!!
Youâre welcome
You want flash your smartwatch ? R.I.P.
The microphone with Google Voice is horrible.when i use in Gboard.
What are you talking about? Itâs not so hard to flashâŚ
Yes but I say that because the watch will disconnect during the flash if we put it wrong on the support so be carefull, it happened to me and several people here.
DONâT TOUCH THE WATCH DURING THE FLASH
Good evening, I received the last update that you published, on which I salute your exceptional work, and I thank you for the opportunity. I encountered a problem during the installation, I reset my Kospet Prime watch to the factory condition, and during the installation it starts then there is a message said âerrorâ a nothing more then. Please guide me how to do this update. And many thanks to you in advance.
Iâm sorry, Iâm not very strong in English, so I wrote in French, but after your remark I used a translator and re-wrote my message. Thank you all.
Sorry i dont fully understand your question . Are you attempting to flash your watch with the latest firmware ? .
You can pm me in french if needed. But you certainly got something more than just error. You can always try another time and see what happens.
Hi guys. Finally yesterday at 5:30AM I flashed and upgraded firmware with download option as tutorial.pdf said. Special thanks to @PeppethustrA for the help and links and @Dr_Andy_Vishnu and @SmartWatch_Ticks and @Malex
I would add to pdf tutorial these points :
A) @PeppethustrA said, disable windows 10 driver signature verification:
I did it through this option, which I considered easiest and donât need to restart:
B) Because flashing tool folder comes with several tools, the flash tool to use is located in: Tutorial\MTK_USB_Driver_exe_v1.1032.0\MTK_USB_Driver_exe_v1.1032.0\v1.1032.0\InstallDriver.exe
C) If update firmware fails:
First tries failed upgrading firmware, so I unistalled driver as it says in:
Tutorial\MTK_USB_Driver_exe_v1.1032.0\MTK_USB_Driver_exe_v1.1032.0\v1.1032.0\ReadMe.txt
Run from CMD (Command line, open start and type cmd)
InstallDriver.exe -u
Reinstall driver again running InstallDriver.exe
D) Before put the watch on charging dock, make sure itâs shutted down.
E) Donât touch the smartwatch while downloading
F) Revert changes and enable again windows 10 driver signature verification:
My feelings about firmware: now smartwatch is faster than never, itâs really amazing how it feels with new firmware, itâs like having a new smartwatch.
Thanks again.
I am happy that you have succeeded and taken another step to expand your knowledge.
this is one of the tasks of this forum, I think
Thanks,you are welcome.
Hello! I flashed the latest 1.8 May update after quite some problems, which finally solved after I disconnected my BT mouse and changed the USB port for the watch dock. Spflashtool wouldnât do the firmware upgrade before this, but it worked once with download only mode with the preloader unchecked. That made me curious about the differences between the two, could anyone please explain the differences between download only and firmware upgrade (which Iâve seen is the recommended one for the prime)? I tried google-ing it but couldnât find much about it.
