I know I asked this before but can you tell how to get back original android system of this watch please
You have to flash it:
-D09_KOSPET_PRIME2_V1.4_20201031.zip - Google Drive
Same way As Faw?
Yes, exactly.
Can u give me the link of tools that I need ?
I mean flash tool please
Just 1 thing in dropdown menu I need to change to upgrade?
Surely you noticed that there is a search function here?
We can’t just keep posting the same thing over and over again…
I already gave you the links one month ago. I’m not willing to look for it twice…
This file will make it fully original system right?
Just try it…
Set firmware upgrade right?
Sorry, but I’m not going to repeat every single step I explained to you on May 17th. You can just read it again…
Thank you for understanding.
I just flashed to stock 1.4 but cant access to apn says not available for this user.
So the question is if I again flash to faw version wil it fix it?
Says invalid scatter file
Just read the original post of the FAW firmware topic, everything you have asked has already explained a few times.
I am so sorry for tons of same questions but couldn’t find answer for 1.1v I mean do I need to download this or version 1.0 is enough(any improvments in 1.1v?)
Maybe I cam answer this question for you since I’ve been flashing custom ROMs since the early days of Android.
What I’ve noticed is developers typically re-release the same firmware with no changes or improvements whatsoever. The only thing that changes in most cases is the build number.
Almost downloaded 1.1 so should I update?
If this won’t affect badly I’ll update
Currently, it doesn’t matter too much. You can stay on V1.0 and then update to V1.2 once it is released.
Ok than I won’t update till valuable update will be released
Thnx a lot for respond
