If you can provide a bugreport i can take a look.
- Download adb_logcat.zip
- Connect your device and enable USB debugging
- Click on adb.cmd and enter:
adb bugreport
adb bugreport
i tried to get Access to my Notifications with the new Firmware, but no luck!
Granted all Permissions on Nova or Square or Lawnchair …
Pretty shure i did something wrong, but what?
Has anybody an Idea?
One more:
How to stop the Pedometer Service in new Firmware?
Privacy - permission manager - physical activity - then deny what you need .
Could you elaborate a bit more please
Thank you
Just had the first “hard” reboot (i.e. with boot logo & music) using the stock launcher. It happened about the time of the fatal signal at 16:14:49 - logcat4.txt - Google Drive
I have been using my upgraded watch for a few days now and want to say a big thank you to all the hardworking people who have obviously put a great deal of high calibre brain storming into such a comprehensive and massive improvement to the watch interface. Thank you very much.
I have no idea if it is feasible, but can the reliance on frequent use of the somewhat delicate buttons be side stepped to access the Power, Re-boot, recent task and circle/square menu?
I use smart touch pro, with this you can access power menu and lots more without use of the buttons.
app is no longer on playstore but can be found on sites like apkpure etc
Thanks for the feedback and yes, we will definitely discuss this.
But no promises
Yeah, that’s a good alternative
Look in here for floating toucher . @SmartWatch_Ticks favourite app
https://drive.google.com/drive/u/0/mobile/folders/1LMppQDWcYxmqbXo-m-sOMDwhhswDZU-d?usp=drive_open
I think it might be possible to add something like a ‘three touch tap’ or ‘right side swipe’ gesture to open the powermenu.
Another hard reboot with the stock launcher - logcat5.txt - Google Drive
Yes, this has been explained here and will be fixed on the next build.
Thank you
Antother cool app to load
It is extremely curious to me that you are the only person who has this problem.
So we are pretty much stuck because of the isolated nature of the problem and all the apps that are being used.
For example, have you tried running the watch with nothing else installed?
Then add one app at a time over a period of days and try to find out what app is pushing the reboot…
When it reboots does it factory reset and you lose everything . How hot is it ?
@none said he found a fix. If it’s still a problem in the next build I’ll do as you suggest.
@Dr_Andy_Vishnu: No, it’s just a reboot, and it’s not warm at all.
Fair enough . Thankyou
Btw when Ian the next built releasing
