Have you read the post explaining the new wrist gesture orientation?
Indeed I have. It almost never works as described.
I assume it is about a custom watchface that initiates the heartrate reading?
It’s with all clockskins, mine and the stock ones.
I tested on Beta 6 on both of my devices, the behavior is the same. I downgraded back to Beta 5 on one of them, did a wipe and in the process of restoring data so I can just use that again for now so the screen comes on a bit more reliably.
Ok, I’m glad it’s working for you (edit: not saying this facetiously). However, I’m 100% sure it’s broken here for me. It’s stuck on 103. After reboots and resets, it never changes, even on the stock clockskins. Again, it doesn’t even TRY to read, the LED never blinks but it works just fine with Universal Launcher.
Update: Now I’m just stuck on 000. Still not seeing the LED even trying.
After a day using the new implementation of the lift to wake, I must say that I prefer the previous methode. Now, most of the time, I found myself using the double tap to wake the screen (faster). So here is two suggestion about this feature:
Make a survey in this thread about witch implementation that people prefer
or:
Create a configuration panel with a long press in the quick setting (lift to wake button) that will allow:
Select the sensitivity (and/or any other relevant parameters like x,y,z angle to wake and threshold)
Bonus: select the prefer implementation (B6 or legacy)
Also, the lift to wake should not trigger when the wrist is in the opposite direction (45 deg reverse). With B6, I found that the screen always turn on while I type on the keyboard.
Tilt to wake uses far more power than double tap and this is why we introduced it.
Fine tuning of the tilt sensor is not possible. There are a couple of parameters that can be used but not sensitivity or anything like that.
In my openion its difficult to master at first because it requires very very light tilt … which is hard to acheive fast if you were used to a bit harder tilt from the previous method…
Anyway i wasnt a fan of tilting to wake…
Still not a fan of that …
Prefering the double tap method which is great feature of this international firmware
So far I’ve not run into any issues with B6. I really like the enhancements made for the volume and desktop. I’m not a tilt to wake kinda guy so I’ll stick with the double tap.
NOTE: I did not do a reset, but will if I run into an issue prior to reporting here. Thanks again for the continued work and support.
You will be waiting a very long time.
It may never go OTA because the brands may not be totally in agreement with the choices we have made - even though they are necessary.
This is why we prefer to stay “unbranded” and not upset them.
The solution provider is supporting us with the firmware, not the brands.
We will be releasing our FAW international firmware for the Optimus 2 soon, with all Google apps intact and with ridiculous apps removed.
This means that the “Dual System” mode (split launcher) will be gone.
You can enable power saving mode if you need to.
So, if you like to have the two launchers for the same OS - I advise you to stick with the stock firmware.
We have been tackling a power consumption issue but we have made a lot of progress. Hopefully we can release it soon
Updated all builds on the original post.
These are de-facto final V1.2 builds that will be posted as well on the corresponding threads if no major issue is found here.
Thanks to the beta testers for their continuous testing and feedback.
It would also be good to know if anyone else has this problem because I have not seen it?
Are you sure it is not because you are having trouble with the smaller reboot menu icons @anon5802783…?
I remember that you mentioned that before.
