The firmware file is not visible on the OTA application, or the upgrade process fails?
Can you tell me when you flashed that version? Where did you get it from?
@ic.dcandelori
I suspect it might be because the newer product (from the last two weeks onwards) has a slightly different board.
It would be really useful if you can tell us where it failed. Is it after the update starts - just after reboot?
Hi Pablo, I replaced standard firmware many time ago. Firmware Z32_Pro_30.04.21.7z has date 05/05/2021. Iām not sure but I suppose to have downoaded it from this site links
Anyway, now I suppose to have to restart from a firmware installable by flash tool that allow then to use the local update with the goal to install B5 version. If is it right, can you let me know the right steps to follow?
Bug:
- Not working Hand Brite (LEM15).
Working after flashing your new factory rom: Z36_LEM15_V1.2_20210510_20210510_145934.
After install factory, can install B1.
Thank you.
Pablo,
I do not see the link to download Beta 6? Am I missing something or is it just not visible right now?
It is currently in progress.
I just prepared the original post for the changelog, but unfortunately didnāt erase all traces.
lol, they donāt miss a trick here
ā¦
Updated builds on the main post to BETA6.
The wrist gesture orientation was adjusted on all models, it works now as:
- Hold your wrist straight.
- Tilt the wrist slowly to a 45° degree angle away from the body.
- Pull the watch back in your direction.
Thank you man!
I am making some changes on the back end storage⦠Please be patient if you have any problems downloading.
Everything will be ok.
If you have a problem, just wait for 30 minutes or so and then it will work.
Pablo11.
where it is? because it doesnāt work in lem12pro, but it would be useful
Hi, solved. I restarted installing official firmware and now Iāve installed B6. ths for your work and support
Long press this button (sound toggle):
Great option
thanks it works
Hi @none,
So far, this seem to be the greatest beta release. Here some comments (LEM14):
Added volume control to sound toggle quicksetting (long button press).
Verry useful feature!
Fixed a problem with the heartrate application timeout counter.
Heart rate reading seem to work at rest (under 100 bpm), but still show random reading when not on wrist.
Updated the launcher overview and transition settings menu (long touch press on the app drawer).
Cosmetic issue: When long touch on the app drawer, the item is selected (like a click) before entering in overview and transition setting menu
Various smaller adjustments and fixes.
- Legacy android app display are now ok in full screen and scaled (Thanks!)
- No sure if it is a bug, but since the install of B6, factory reset and app restore, the night light havenāt automatically turn off after sunrise (day time).
- This firmware does not have the latest Google app, and 10 Google apps must be update after a factory reset (Google map, Google chrome, Contact, Clock, message, calendar, etc). It would be great is there is a way to implement the open gapp version.
Hey guys, thanks for the new beta 6. But it looks like something isnāt right here. Tthe lift to wake seems rather insensitive and sometimes VERY slow to respond. I mean like maybe 10 second delay slow, if it responds at all. I literally put it side by side with Beta 5 to make sure I wasnāt just being overzealous (though honestly it doesnāt really work properly in Beta 5 eitherā¦and yes, my wife laughed at me for walking around with 2 watches on). Of course, I reset and wiped before posting this.
Also, the heart rate is still completely broken on the home screen but still works fine in Universal launcher. The LED never even blinks.
Well, thatās a limitation of the driver/hardware, those drivers are partially prebuilt so there is only so much that can be adjusted here.
You mean the highlight on the app icon? That is intended, since the launcher canāt predict if you do a short or long button press.
This firmware does not have the latest Google app, and 10 Google apps must be update after a factory reset [ā¦]
Those packages are distributed by mediatek and the last version is from march, unfortunately until an update is provided there isnāt much that canāt be done.
[ā¦] lift to wake seems rather insensitive and sometimes VERY slow to respond [ā¦]
Have you read the post explaining the new wrist gesture orientation?
I assume it is about a custom watchface that initiates the heartrate reading?
