I know this is difficult and takes time so i thought i would share a template on how to do this . Looks much nicer on watch faces than the usual text battery percentage . Pay particular attention to the order of images . Feel free to edit and use as you wish . I have included :-
thanks for the excellent work, I was trying to resize the Digital Clock Layer because it is very large, but I can’t resize it, how can I do? Thanks again
Okay . You need to resize each image in wfd and save them . For example , start with the image zero . Open in wfd , alter scale and move to desired position . To keep this simple write down scale size and position for other images as you will be altering each one exactly the same . Save it and make sure you keep it as the same file name as the original . Do this with all images 0 - 9 . Save all the new images in a separate folder until finished then replace the originals . I hope this makes sense . There is another way but try this way , should be easy
thanks a lot seems to work, given your kindness, a question if I can, I put in a digital clock, but when I go to indicate the font style does not see me the new fonts loaded in windoes 10.
I’ve uploaded new fonts in windows 10, digital style fonts, but in WFD you don’t see them, do you have a solution? thanks again for your cooperation
I’m quite sure that it doesn’t work, because it’s a jar file. If you want to use an other font for the digits, create them as a picture and upload them in WFD as pictures.
