Are the fonts you are adding/downloading in .ttf file format?
Thats what i am using on mac . No idea on pc
I tried to do the numbers with Gimp, but I canāt remove the white background
yes, I repeat in word everything ok but in wdf does not see them
I have image with a background erasor . You will need something like this to make background transparent . Check out @Louis_Peek post
I managed to create the numbers with gimp, but how should I load them into WFD?
In WFD you can change all digits 0 - 9 to images . When creating a digital clock look at the very bottom of page in settings . Have a good read through the WFD thread . Thanks
yes I have seen and tried, but also uploading all the images of the numbers, including separator (
I donāt get the digital time, but only one number or only the separator, I donāt know where Iām wrong
I will have to look later . Away from my computer
hello, did you by chance try to see if the images work as a digital clock? I tried them all but I couldnāt. thanks again for your help
Hi . Images work 100% as a digital clock . I have faces on my watch now with them . Check you have set to hour and minute in wfd . Also try altering scale . Let me know . Thanks
https://drive.google.com/file/d/1w2yXUjrVTPnBrCbCxh-ThNjdxmEfUNAd/view?usp=drivesdk
I made this for you . Load into WFD and you will see what you have to do
thank you very much, I was wrong in making numbers with GIMP, I was making a new transparent image 400x400 pixels, thanks again for the help you were very kind and understanding, thanks again
Your very welcome . Happy to help
Fonts should work with WFD. After installing a new font (using the operating system installer - just double-click the font), youāll need to restart WFD so that it sees the new font. Thereās no need to restart the computer, just WFD.
Thanks Marco
. Your support is appreciated
hi guys, can you tell me where am i wrong?
I tried to reduce all the images, but in preview I always see two images of the battery on the watch.
I canāt overlap them so that only one image appears.
thks
The best way to do this is create a new set of resized battery images ( all of them ) . Position one as a image only and resize . Save this as a image only . Then do the rest . Then start your new face and load them in . Otherwise it can be all over the place . And dont forget WFD will position the battery the wrong position on your watch although in preview it will look correct . Change the x value - 200 and it will be right
Thks Andy,I resized the image set again, loaded in wd and now it is ok, and understood why at 100% and under 10 I had no image.
Forgot to mention i always have the empty battery image as a fixed image on clockskin . Then the battery images on top
