Great new video for flashing firmware by Mr Ticks.
Hi . You have just posted there is nothing wrong with the side buttons but they dont work ? However having to open up the watch to get them to work isnt good . Sounds like a hardware issue to me . Never harms anything flashing the stock firmware when watch powers off and runs out of power .
Dont forget to select firmware upgrade in SP flash
Upgrade does not have anything to do with buttons.
If you seriously have issues with your buttons you need to return your watch.
But to be clear - the buttons are not used for flashing firmware.
Just FYI.
Strangely enough - all the latest drivers and tools can be found here -
Drivers:
SP Flash Tools:
I think that it will not be possible to exchange or return, almost 8 months have passed, although I will turn where I bought. And I know that buttons are not needed during firmware, commands come from PC
Thank you, Pablo, I will try to update the drivers in the evening… But there is a suspicion that the problem is either in the watch or in the usb wire
Thanks, I did it several times with the package “flashing tools”, I do not understand why it does nothing when I connect the watch, no data are transmitted to the watch, ant idea ???
Is your watch powered off when you connect it to the pc?
You have to click on the download button in the flash tool app and then connect the watch to the pc.
But watch must be powered off when you connect it.
Yes, the watch is on the dock so charging mode but OFF
Don’t ever use the charging dock.
Cable should be connected directly to the watch
And you don’t connect it to the pc until flash tool is ready and you have clicked download.
I learned the instructions for installing drivers and firmware through Flashtool by heart. Why the MTK phone is determined in the system and updated, through Flashtool without problems, and the watch does not want. Why dont you assume the problem is the watch?
Probably becuase we spend all day every showing people how to flash watched after hundreds of failed attempts . So far i have yet to see of hear of a watch that cannot be flashed . However yours could be the worlds first
You can not answer and not waste time, I understood everything. I probably dont understand anything, I wont write more about the problems. Thanks for your help
I just discover the message, and I did the same conclusion as you, I decided to replace the dock with the 4 pins cable and it is ok… so may be you should modify the tutorial as it shows explictly the watch on the dock… Thanks for your help, I didnt remember how to do a factory reset but I m trying to find the solution on the forum
Ok I got the factory reset
A post was merged into an existing topic: FAW release candidate 1 v1.3
I tried again installing firmware V05 (no problem). I uploaded the firmware V06 zip file to the internal memory, I entered configuration / firmware update, I chose the zip file, the smartwatch turned off and it indicates an error. (I fixed the free space of the scartyer loading file and it is not the cause of the failure either)
Does anyone have the MTK for the Lemfo 12 pro firmware V06?
Could you check if there’s an IMEI?
