Now it worked. Thank you very much for your help and patience. I hope that the watch works flawlessly now. Greetings Volker
flash the original stock firmware with sp flash tools first
Maybe this question will sound stupid but I need to ask
How I should figure out when new updates released?? I want to keep up to date my watch
If new update released I need to update from link on top of the thread?
Flash it once again. Use the firmware update option in the flashtool.
So iâm assuming you didnt follow the instructions and didnt use " firmware upgrade option " in flash tools ?
Yep - Firmware Upgrade mode actually takes a backup of NVDATA and carries it across to upgraded firmware on install.
Format All + Download is the option that wipes it all out, IMEI, Wi-Fi MAC and Bluetooth MAC will be gone and an NV error will appear in Wi-Fi settings because MAC has gone.
Easy mistake to make if you are not careful - but unfortunately quite difficult to repair afterwards and not covered by warranty.
Using a MAC is not going to work as we know but Iâm curious about âwire wobblingâ and also which firmware was flashed and which drivers were used?
Because - the cable is rock solid, the drivers are very simple and the firmware flashes perfectly - so I am puzzled by this
The only way to delete the IMEI, Wi-Fi MAC and Bluetooth MAC is to use the format all and download option. So this is what you accidentally did. It is possible to fix it, but we canât help because itâs not legal. But Google will lead youâŚ
Can you give link pls
Yup I did local update
But this is dor optimus 2
How to downgrade?
Make sure you select firmware upgrade
dropdown menu â> firmware upgrade thatâs all I want to know
cause I dont see downgrade option
Flash to Faw 1.0 than to beta 3 right?
No . Flash the original firmware i posted the try the FAW firmware ( follow the instructions from stock )
thnx a lot soz for bother just notification bug makes me nervous
Maybe I shouldnât update to beta 3?
The latest beta is fine
