25% in 24 hours is normal battery discharge. Thank you for the info
@bolzanos I am curiousâŚ
Normal compared to what�
Just interested
Iâm just wondering if itâs okay
Ah ok.
What do you have enabled while you are measuring battery life?
WiFi, Bluetooth, cellular data or none of these�
Just trying to understand what your idea of watch battery use involvesâŚ
WiFi, thatâs all and the phone turned on
Ok cool.
Wi-Fi enabled and signed in to Google ?
Why canât I install the new update on the prime2 I have asked now for 6 weeks now I tryed 5 times to install the UNIVERSAL UPDATE and I always get UNSUPPORTED FIRMWARE
Which firmware version is currently on your watch?
What can I do against it ?
Flash this package with the SP Flashtool to perform a factory reset:
factory_reset.zip (7.8 KB)
Where can I find the right SP Flashtool? There are many versions
Current SP Flashtool version and driver:
Big thanks
I have to bother you again. Sorry. Now I donât know how to do it with the Flash Tool and the ZIP file. Could you tell me exactly how to go about it?
have found
In the âfactory_reset.zipâ there are still 2 files: cache.img and userdata.img. What do I do with it?
or what do I do with the factory_reset.zip file
Sorry but I donât understand anything anymore.
Iâm totally confused now.
I have a Kospet Optimus 2, not a LEM 14.
What exactly do I have to do now? Driver and Flash Toll is installed.
MT6765_Android_scatter.txt is inserted.
factory_reset.zip ???
What exactly should I flash with the Flash Tool?
I was just thinking of doing a factory_reset fix.
For Factory Reset by flashing
The procedure is the same, only the devices are differentâŚ
Here is a step to step instruction:
- Download and extract
factory_reset.zip - Download and extract
SP_Flash_Tool_V5.zip - Open
flash_tool.exeand click choose:
- Select
- Click Download:
