Dec 1, 2017 11:49:25 GMT 1davefraud said: No Sonia, I got two google services from the first star after flashing firmware. Every time I tried to reset my watch I always got two services running
ok, that is not normal, flash the watch again with the firmware first reset and then flashi it again, if you still having problem (do’nt install nothing just check the google services and google play store) plz let us know.
I’ve done three times with the same result and it seems I’m not the only one with this issue…
Dec 1, 2017 12:03:54 GMT 1soniasophie9697 said: ok, that is not normal, flash the watch again with the firmware first reset and then flashi it again, if you still having problem (do’nt install nothing just check the google services and google play store) plz let us know.
i’m checking…i did’nt flash my watch with the new upgrade i will do that and see if i get the same result but also will notify.
***edit:when you did the upgrade did you choose upgrade option on sp f.tool?
What does it say next to the second google services?
I see you have Clockskin launcher installed.
Can you flash the firmware and install absolutely nothing please.
We need to identify the culprit here.
Dec 3, 2017 2:10:57 GMT 1RASC Moderators said: What does it say next to the second google services?
It say “ persistent”. I will reset my watch and I’ll post picks thanks
i’m not sure if the info here are in the same hours cos i see different readings.
you have 2 google services and that can only happen if you use social media like FB or Whatsapp and that can cause battery draining really fast.
Hey guys hope you don't mind that I will hijack the thread .
Seems I have similiar problems with battery it’s getting hamered with screen off.
I don’t use sim card and have only BT on connected to watchdroid.
Only apps I installed are Universal Launcher, Gsam battery mon, settings search, watchdroid.
Now here is a funny story I have… wait for it 3 google play services active according to settings search.
The funny thing is that I didn’t even setup my google play account, didn’t even start google play. All the third party apps were sideloaded from SD card.
I didn’t want to setup google play to get better battery life but seems I failed:)
do'nt do nothing just reset the watch and notify us if the problem still there.
I have closed all google play services using GSAM BM and it's been close to 24hrs and not even one has been activated since. So far I seem to have great battery life - used 14% in 4:30 hrs with BT on and about 15 minutes of screen on time. Will keep on checking if it stays that way.
Suerely there is something wrong with google play services. I downgraded it and ‘turned off’ and i have 1% on hour drain and estimation around whole three days.
Dec 17, 2017 14:36:37 GMT 1Kyokushin said: Suerely there is something wrong with google play services. I downgraded it and 'turned off' and i have 1% on hour drain and estimation around whole three days.
There is no one size fits all and there are other ways to deal with this but I have used Hibernation Manager on all my Android watches to turn off Google Play Services and other non essential apps when the watch is asleep. And as I have documented in the several battery tests I have run on this Forum I get about 20+ hours of run time on my watches. Simple to use and works for me.
Yes 3g and no Bluetooth connection for notification
disable any sync and updates on google play store and any app that does that, this drains faster the battery. try using 2g most of the time even though you are using data connection.
I had everything off. I just wanted to ‘format’ battery. Its best to charge when it is turned off, then discarge at lowest power consumption. Around 3-4 cycles and you will gain more power from battery. I am doing it since years (i know modern batteries do not need it in theory), but finally, my friends ceelphones are working 1-2 days and mine always 2-3 with same usage.
Record was 114 hours uptime.
you got from 100% to 39% in just few hours??? that is not correct, reset the watch and use only 3g without any apps then we'll know what causing it. do'nt set accounts just use the 3g.
you got from 100% to 39% in just few hours😧 that is not correct, reset the watch and use only 3g without any apps then we’ll know what causing it. do’nt set accounts just use the 3g.
No chance…after the reset I started my whatch fully charged at 9am and now it’s 3.30pm I ve 9% only 3g and no apps
