Verizon primarily uses the CDMA network. If you experience an issue using a Verizon Sim card it most likely is not a compatible Sim for the GSM network, required for these watches. Here is an information page that may help explaining how they operate.
I would suggest using a T-Mobile Sim card from Speed Talk. You can get one for as little as about $7 a month.
Yeah,regarding the watch connection. Is just me but the waych connects to pc but for some reason i cant copy anything there? Anyone faced an issue like that before? Sorry for such big amount of questions, just got mine 2 days ago and its a first smart watch.
I have LOKMAT APPLLP 4 PRO watch.
When i connect it Windows 10 detects jt and i can see it in connected devices in my PC , bit when i start browsing the watch directory from PC and try to move something in it it beggins to be laggy, sluggish and unresponsive.
Pc is fine it works OK with other hardware.
I tried to copy a watch face and it was like taking forever, after that kching windows notification sound and nothing happened. Maybe that is watch firmware lag? Or i must get some kind of a permission in watch settings or something else. Thanks for any kind of help. Untill now managed to install custom skin straight on a watch,using Zarchiver and built in file manager.
Wondering if its only my issue or somebody else has similar story .
Rebooting the watch usually fixes the file transfer issue. After that it should be fine.
If not, please add it to the spreadsheet.
If have a look through the comments here you will see a few people here have had this problem.
FYI all,
I have submitted the spreadsheet but I did it the day before the Chinese autumn festivalā¦
Unfortunately everyone is on holidays in China until next Monday.
So I hope to get some feedback middle of next week.
I had the same problem, everything was installed right, but I can not drag and drop to the watchface directory.
You can use the app
clockskin-transfer from Marco:
This works very fine for me.
Install this app on your smartwatch, start it and put in the shown parameters in your browser on the PC. Then you can choose a zip file from your PC with your watchfaces to be sent to your smartwatch. Send it, Thatās it.Restart the watch and the new watchface is available.
This nice tip was send to me by Dr_Andy_Vishnu (moderator here)
Thanks for the feedback.
I am puzzled by the way @Eric_Crochemore and me can use copy and paste to the clockskin folder on the watch from our PC once the watch is rebootedā¦
Greetings guys. Today i have encountered quite an annoying feature on my Lokmat apppllp 4 pro ,which automatically enables itself since you unlock developer options by tapping 7 times on a build number of your watch. ( Needed that to enable usb debugging to run Vyzor, to install volume control app) Somehow i have no idea how the screen rotation feature enables after doing so, and i havent found any solutions except factory resetting the watch. It would be very nice to implement the screen rotation block button or at least an option in the future updates. Maybe im dumb and i just didnt find how to stop that,but yeah. Just wanted to make you people aware of that. If there are any other ways to prevent your screen from turning around i would be really happy to know. Thanks.
I have one idea about your issue, but I donāt sure itās smart, because I donāt use appllp 4pro. I have used LEM16.
The watch has āauto rotation buttonā on status bar as normal Android. But on stock luncher, we canāt access status bar directly. If you use some apps, you can access the bar. I am using Tasker for that. Other apps, these can access āstatus barā, I think you can set rotation status.
Thanks for your suggestion. Will keep that in mind if i encounter this phenomenon again. I just dont understand why the hell theres no such button(option) if the watch is capable to autorotate the display. And i have no idea why it starts spinning when you unlock developer options. Little bit weird. Have a great day.
There are a few apps available that allow you to access the āAccessibility Settingsā.
Settings search is not available on the app store any longer, but it is posted here on the forum if you search for it.
The screen rotation function can be enabled and disabled in this hidden section of settings.
I have also noted in the feedback spreadsheet that the settings app needs to be opened up and not so ārestrictedā
I noticed that someone has a problem with the step counter being stuck in the spreadsheet.
This is usually fixed by a factory reset.
If this doesnāt fix it, I would suggest that you get a replacement because it is unlikely to be a firmware problem.
