Need firmware for this device. Mtk6739 Android 7.1. Help!
what happened?
what happened?
Unsuccessfully flashed TWRP)) I received a firmware from Zeblaze technical support. I’ll link to download later. Maybe someone will need.
Firmware for Zeblaze Thor 4 Plus MTK6739 Android 7.1.1
build number KY_THOR4_PLUS_20181124
drive.google.com/file/d/14P4iTZwQR-PXN5I3Y-XWhzEv1DRNUHFm/view?usp=sharing
Dec 12, 2018 13:14:20 GMT 1 gunjobas said:
Firmware for Zeblaze Thor 4 Plus MTK6739 Android 7.1.1 build number KY_THOR4_PLUS_20181124 drive.google.com/file/d/14P4iTZwQR-PXN5I3Y-XWhzEv1DRNUHFm/view?usp=sharing
i just hope that this watch does'nt have different type of screen as many other watches:/ that means different firmwares.
i just hope that this watch does’nt have different type of screen as many other watches:/ that means different firmwares.
I went with the firmware from the LEMFO LEM7 M6739 Z28s model for several days. Took from this post /thread/2936/lemfo-lem7-m6739-z28s-model
Everything worked fine except the Back button. On Lem7, it simply does not exist)))
let me check if we can get the FW. good to know that lem7 FW works on it.
Camera is not working
zeblaze thor 4plus 4G
Need firmware for zeblaze Thor 4 pro help! After installing app, went to bootloop.
Version: XY_THOR4_PRO_20181121
KERNEL: 4.4.22+
WED NOV 21 21:29:29 CST 2018
Dec 22, 2018 17:00:26 GMT 1 cabeleira said:
Need firmware for zeblaze Thor 4 pro help! After installing app, went to bootloop. Version: XY_THOR4_PRO_20181121 KERNEL: 4.4.22+WED NOV 21 21:29:29 CST 2018
ok, i’ll notify about this.
The version on this watch in the photo is 20181121
I have version 20181205 which I will upload for you if it helps?
I’ll be very pleased (pablo11), even though It’s not the same version, I’ll flash the firmware anyway, I just got my watch 5 days ago
Dec 23, 2018 4:43:59 GMT 1 cabeleira said:
I'll be very pleased (pablo11), even though It's not the same version, I'll flash the firmware anyway, I just got my watch 5 days ago
This is the latest version I have at the moment drive.google.com/file/d/1epamw3L7YP2NL6QqMYkQqRcCDxY3UhXr/view?usp=sharing
Please note - new flash tool included.
If you already have V-Com drivers installed you are good to go.
Our YT Channel has videos ( www.youtube.com/channel/UCPt33KEKqPJfxFTf7CaKcFw/ ) for flashing and there are many more available on the web.
Please make sure you know what you are doing before you try this.
Thank you so much mate, you just made my day,I just finished flashing your firmware and got my watch back again!!! Thank youuuu!!
No problem ![]()
On Zeblaze Thor 4 Plus firmware from 10.12.2018 there is a link?
I will see what I can do.
If it is not already in the Zeblaze firmware thread - have you checked?
Ok, I just got this version.
I will upload it soon.
Pablo.
