Thanks for your help. When will a link to a new firmware version appear?
Dec 29, 2018 15:37:39 GMT 1 serggg said:
On Zeblaze Thor 4 Plus firmware from 10.12.2018 there is a link?
What hinders to deliver on the promise?
Sorry - I went away on holiday and forgot about this…
Here drive.google.com/file/d/15F_ryTpPlyTLOcmWdCisEY7NCt4egTN1/view?usp=sharing
Jan 7, 2019 3:07:45 GMT 1 RASC Moderators said:
Sorry - I went away on holiday and forgot about this...Here drive.google.com/file/d/15F_ryTpPlyTLOcmWdCisEY7NCt4egTN1/view?usp=sharing
Thanks so much. Installed the firmware successfully.
Hi
I ve installed Thor 4 pro firmware linked on first page bit brightness is very low i cant see nothing at max brightness
How can i fix it ?
Dec 12, 2018 12:08:17 GMT gunjobas said:Dec 12, 2018 2:29:47 GMT soniasophie9697 said:
what happened? And Bluetooth and camera is not working
Unsuccessfully flashed TWRP)) I received a firmware from Zeblaze technical support. I'll link to download later. Maybe someone will need.
Seems to be a recent update. just going to install it now.
Feb 7, 2019 9:43:31 GMT 2 xxoglocxx said:
Hi I ve installed Thor 4 pro firmware linked on first page bit brightness is very low i cant see nothing at max brightnessHow can i fix it ?
The brightness has changed after the update? That is weird, reset the watch (guys always reset before flashing) and see if it changes if not install Dimly and use it to see if you can change it if not notify here.
