zeblaze thor 4 LTE
Jun 9, 2018 18:40:51 GMT 1 mgk said:
they both the same watch just different look, the lem7 will give you what you need. i have a new lem7 just got it, i'm testing it as an activity watch for me this is the most important thing, google play store and services works fine, i've tested it a full 24hrs of usage just gps and 3g on, 4g is terrible but great when you want to download something fast and you not near wifi. i will test the wiiwatch 2 and notifications i mainly use m2d cos i can use it with 3g so no need for the whole day to be on BT cos i'm using it everyday for my activity at least 2hrs, you'll get 24hrs with the lem7. i am going to do some videos on it this sunday and more especially considering battery life.
they both the same watch just different look, the lem7 will give you what you need. i have a new lem7 just got it, i’m testing it as an activity watch for me this is the most important thing, google play store and services works fine, i’ve tested it a full 24hrs of usage just gps and 3g on, 4g is terrible but great when you want to download something fast and you not near wifi. i will test the wiiwatch 2 and notifications i mainly use m2d cos i can use it with 3g so no need for the whole day to be on BT cos i’m using it everyday for my activity at least 2hrs, you’ll get 24hrs with the lem7. i am going to do some videos on it this sunday and more especially considering battery life.
Hi Sophie! Please report what’s happening when you say “set timer” with Ok Google listening offline! Thanks!
So I have to decide : lemfo lem7 or Zeblaze Thor4. I don‘t need 4G, but good battery for ( hopefully ) more than one day to be independant from my smartphone. And as I am reading every comment here in this forum, it is very good to know that there is help if help is needed. So my requirents are : Android 7 Good battery / >1 day ( low usage with 3G always on ) Service/ help here in this forum if needed Individual watchfaces Google play store i do not need 4G .........
What is your advice to buy ? ( my old No.1 D5 is still running, but the wristband doesn‘t look very nice after 2 years permanent wearing and the battery doesn‘t last for a whole day ( low user )).
You may want to check this video
It’s comparing lem7 and Thor4 include battery life.
Apparently, the f/w looks not exactly same. It seems like very small differences on those 2 models.
Yep, base firmware is exactly the same. But as I said before there are some cosmetic software differences.
The screen raising difference is purely because the Thor 4 is using a more up to date firmware than the LEM7.
Thor 4 only left the factory a couple of weeks ago.
LEM7 left the factory a month ago.
The updated firmware for the LEM7 which we have posted is the very latest. It has a much better screen waking response now - just like the Thor 4.
I would choose the Thor 4 simply because it uses the bezel overlap to hide the black ring around the screen.
Hi Pabllo, Do you have any idea why the battery life is such different between T4 vs LEM7?? I was guessing, identical result. Also, wondering if f/w udpate will address the GPS issue which this video is pointing (if it is caused by f/w). Chigz wasn't able to install Antutu into LEM7. Do you know if the new f/w will allow installing Antutu into LEM7?
I just got my sample yesterday
Same for 2 other moderators here.
So we are investigating the diffences.
However, I work with the solution providers (they make the pcb, firmware, antennas and software) and I can 100% confirm that the same board and base firmware is used on both watches.
The difference in battery performance is most likely due to firmware version only, as I said above.
About gps and other things - I have not got a Thor 4 to work with.
I will test antutu now on the new LEM7 firmware
Thanks Pablo.
No, it’s other way around if you watch the video. Thor4 doesn’t have isseu on GPS. The video claims the LEM7 does.
Guessing this is due to the older f/w as well.
Thanks Pablo.
LEM7 still cannot install Antutu... Have to investigate this. Yes I know what you mean and I am looking into it
Ok, Play Store compatibility problem.
I copied the apk to the LEM7 and it installed fine.
But - there is a flaw in the LEM7 firmware that I need to get fixed.
A GPU error.
I’ll keep you updated about this
Can we do Bluetooth calling on this Thor 4?
As I said to you before… No we can’t.
Not on any of the A7 watches.
When it becomes available I will make an announcement.
So I decided on the Thor 4 now. ( cause of the black ring on the lemfo ). Order is done. Thanks to SoniaSophie and Pablo11. Looking forward to have some nice time with this smartwatch.
Guys i have been using thor 4 for 2 weeks!! I have to say that the overall experience is good!
Can some one guide me on how to root it? & one more question is there any way available to install WEAR OS on thor 4?? If yes plz guide me!! Thanxx
Congrats mate....  Hope you have a great experience!
Absolutely no chance of using Wear OS. You bought the wrong watch for that. It just will not work at all with Wear OS
Hi Pablo! So you confirm some Ok Google commands like “set timer/alarm” don’t work offline!? Thanks.
Jun 10, 2018 13:47:24 GMT 1 jrjr said:
Hi Pablo! So you confirm some Ok Google commands like "set timer/alarm" don't work offline!? Thanks.
i've put the watch in airplane mode and no, OK Google does'nt work without 3g or wifi.
Jun 9, 2018 22:40:17 GMT 1 jrjr said:
Ok Google does'nt work without 3g or wifi connection.
