zeblaze thor 4 LTE
Jul 21, 2018 21:12:58 GMT 1 d8nny said:
The watch was faulty so I returned it and bought a thor pro for 1/2 the price, still waiting for my refund from Banggoods. The cellular on the thor pro is as good as my mobile phone ie it works everywhere that the mobile works, the screen is briliant outdoors but the preinstalled softwares needs a lot of work, there are thinks missing like a basic calculator, the security settings is missing and there is no way to kill apps running in the background. I dont use it very heavily and can get 2 days on a charge
that amazing so far only good reports on the thor pro, are you using it fully 24\7 with 3g? about settings install google gesture and you will get access to any settings you need, it is all there just need to know where to look:) use ricktop apps they are meant for our watches:)
Any support please?
Jul 20, 2018 13:52:06 GMT 1 benjuzzo said:
Hi to all, we are two friends and its a pleasure to share with you our experiences with our great Thor 4 by Zeblaze. We have the same problems of others users. We don’t understand if there is a way to give a better graphic interface to the watch, watch face apart, but if there is a better firmware with a better launcher…we didn’t understand that after read all your conversations. We missing something?
All information will be welcome.
Thank you all,
G&S
Thank you all,
G&S
Jul 22, 2018 10:24:37 GMT 1 benjuzzo said:
Any support please?
Thank you all,
G&S
what both of you mean? any issues with the thor 4? what are they?
Has anybody found a clock face with AM PM that works correctly on the Zeblaze Thor 4?
Yes, I have my settings to NOT use 24 hour format.
It seems that the standard clock faces from Zeblaze don’t have AM/PM and any I have downloaded from plus.google.com/communities/109827242607524552712 don’t work correctly for the AM/PM display.
Jul 22, 2018 15:04:21 GMT 1 brucel said:
you can always build one yourself:) or change a face you want:) it is'nt hard to do.
Has anybody found a clock face with AM PM that works correctly on the Zeblaze Thor 4? Yes, I have my settings to NOT use 24 hour format. It seems that the standard clock faces from Zeblaze don't have AM/PM and any I have downloaded from plus.google.com/communities/109827242607524552712 don't work correctly for the AM/PM display.
"Yes, I have my settings to NOT use 24 hour format." I have considerable time in the military where you have to use a 24 hour clock because it eliminates confusion while conversing about time anywhere in the world. Which is why it works. 0800, 2000 is 8 am and 8 pm. You could be locked in a dark windowless room for 2 days and still know exactly what time it is outside without guessing. It works every Time, all the Time.
Is it possible to order an additional charging cable for the Thor 4 ( to put it in to my car in order to avoid getting out of battery )?
Any links ?
ok, I found one here : m.banggood.com/de/Zeblaze-THOR-S-Smart-Watch-65cm-Length-Charging-Cable-With-Port-Magnetic-USB-Power-Charger-Cable-p-1245601.html
That’s a Thor S charging cable, not sure if it works for the Thor 4.
See www.aliexpress.com/item/Zeblaze-THOR-4-Smart-Watch-65cm-Length-Charging-Cable-with-Port-Magnetic-USB-Power-Charging-Cable/32880050744.html for a Thor 4 cable which I have bought and know it works with the Thor 4.
Also found using “Standby Intelligent Power” setting made a big difference in how long the battery lasted.
I've tried building my own clock face and have the same problem with the AM/PM not working on the Thor 4.  So it's either my watch, or a Thor 4 problem, or a overall Android problem, or a setting that I'm not aware of.  I'm guessing it's a Thor 4 problem and may eventually be fixed. Was wondering if anyone else has seen this issue or has a working clock face with AM/PM?
for a better UI and we doesn’t connect on internet through Bluetooth. It doesn’t work.
We cannot reply to whatsapp messages, we can’t connect to watchmaker
Thank you
Thank you all,
G&S
Any support please?
i’ll try my best to see if i understood, wiiwatch 2 only gives you notifications you can’t reply with this app for that it is better to use Watch Droid or M2D. about watchmaker go to G+ community and you’ll get all the help you need how to use it and also watch ricktop great video about it:)
I don’t understand, I can only make my watch face? I can’t use some watch face on google play store?
Yes you can, if they are meant for Android watches, not Android Wear…
benjuzzo
if i’m not mistaken you can use most WFs with Eric’s launcher (ricktop) and you do’nt have to make watchfaces you can download from our G+ community as many as you want.
pablo11 AvatarJun 13, 2018 22:49:37 GMT 1 pablo11 said:
Any Thor 4 owners out there - can you tell me if your watch is overheating please?
Yes my over heard when playin music and even when chargin sometimes
Thanks, can you tell me what firmware you are using? I have just upload a new version for the Thor 4
Hi all,
New firmware is here KY_THOR4_20180622
/thread/2414/official-stock-firmware-thor-updated
Just got my Thor 4. I’m leaving early tomorrow for a vacation so I won’t be able to play with it until next Wednesday, but spending 5 minutes with it I can already tell it is so much higher quality than the LEM6: super zuppy, screen is much better, and buttons have an easier click with a much faster register.
Jul 27, 2018 4:01:55 GMT 1 lincoln said:
Just got my Thor 4. I'm leaving early tomorrow for a vacation so I won't be able to play with it until next Wednesday, but spending 5 minutes with it I can already tell it is so much higher quality than the LEM6: super zuppy, screen is much better, and buttons have an easier click with a much faster register.
They are pretty good watches 👍
My Thor 4 will not turn on. The screen isn’t working. Ive been messing with the power button to make it restart and boot up and sometimes it works and it shows the zeblaze logo, but after that it just goes blank. I need to figure out how to fix this. Maybe I can factory reset without using the screen, but i dont know how to.
