Jun 29, 2017 11:44:46 GMT 1 roundyround said:
wait a couple of days till the sources for the FW will be open and remind me when it is and i'll help you with what you need to do:)
wait a couple of days till the sources for the FW will be open and remind me when it is and i’ll help you with what you need to do:)
Jun 29, 2017 22:14:49 GMT 1 roundyround said:Jun 29, 2017 11:53:23 GMT 1 soniasophie9697 said:
I’m ok with flashing the FW, it’s just very difficult to do if you can’t find a FW to flash…
How long is a couple of days ?
Jul 7, 2017 19:54:57 GMT 1 roundyround said:Jun 29, 2017 22:14:49 GMT 1 roundyround said:
I'm ok with flashing the FW, it's just very difficult to do if you can't find a FW to flash....
Hi,How long is a couple of days ?
sorry, i forgot:) /thread/695/latest-y3-factory-firmware
The Y3 is no longer recognised as a USB device ?
Jul 9, 2017 16:27:10 GMT 1 roundyround said:Jul 7, 2017 21:29:14 GMT 1 soniasophie9697 said:
Many thanks.The Y3 is no longer recognised as a USB device ?
1.make sure that debugging is turned off.
2. go to device manager and install usb mtp:
Jul 9, 2017 18:22:00 GMT 1 roundyround said:
MTP USB is not in the list
Mar 7, 2017 17:41:06 GMT 1 jackster said:
Hi I have this watch aswell and mine has the same ota message. Word of warning i thought the firmware was the same as the kw88 and flashed and bricked it pablo 11 got me the latest firmware which is posted on this forum re flashed and now everthing is fine. If your watch does not show the + sign to add faces then consider the new firmware but you will have to flash to get it.
Hi, can you confirm that the firmware version here in the forum allows you to install custom faces? Thanks
Oct 17, 2017 19:48:08 GMT 1 ruteg said:Mar 7, 2017 17:41:06 GMT 1 jackster said:
i’m not sure but with Eric’s launcher you can install any WF that you want.
I know but on this watch Erics Launcher is very erratic. So I want a stock launcher.
Thanks anyway
Oct 18, 2017 11:10:48 GMT 1 ruteg said:Oct 17, 2017 20:48:16 GMT 1 soniasophie9697 said:
Thanks anyway
edit: you can install custom faces on your watch, look for an update which allows to install custom faces and you should see a folder called “clockskin” you download any WF that you want and copy the folder(not zip or rar but dir folder which contain only png items) inside the zip\rar file to the “clockskin” folder and reboot the watch and you should see it, but be careful do’nt erase any custom watch face when your watch is on one, to make changes in the folder it is better to be on stock WF.
Can some one plz post a video regarding how to install firmware in lemfo y3 ,step by step.
I am a little bit afraid to flash the firmware
(I am afraid that i should not brick my smart watch)
So someone plz help
Oct 20, 2017 15:36:01 GMT 1 jesvi22 said:
make sure the watch is turned off in the whole process.
1. have you made sure that you installed drivers and usb mtp? does the computer recognize the watch? 2. download sp flash tool and extract it. i use v5.1644. 3. download the firmeware for your watch: /thread/695/latest-y3-factory-firmware 4. click on scatter loading file and locate the file of the firmware it ends with txt. and open it, after that all the tables in the sp flash tool should be loaded. 5. make sure that download only is chosen and then press download. 6. plug your watch to the computer and you should see the process on the sp flash tool started and when it reaches 100% you'll see a green mark. thats it:)Oct 18, 2017 11:16:31 GMT 1 soniasophie9697 said:
Thanks anyway
the problem is that this watch is’nt supported anymore and so you do’nt have the update which allows to install custom watch faces. i’ll check…edit: you can install custom faces on your watch, look for an update which allows to install custom faces and you should see a folder called “clockskin” you download any WF that you want and copy the folder(not zip or rar but dir folder which contain only png items) inside the zip\rar file to the “clockskin” folder and reboot the watch and you should see it, but be careful do’nt erase any custom watch face when your watch is on one, to make changes in the folder it is better to be on stock WF.
I dont have any new update by OTA.
is your watch is rooted? install root checker and see.
No rooted.
Oct 20, 2017 22:45:41 GMT 1 ruteg said:
No rooted.
No rooted.
so your watch should get ota, make sure that your watch is more then 80% battery and that you are on wifi and try again.
No new version available…
