Yes, I’ve turned on WhatsApp notification in watchdroid app list. Watchdroid always give me WhatsApp message notification, but not for WhatsApp call.
In version 9, you have to activate the option to capture phone call notifications as seen in the following video.
https://youtu.be/P8FherdV0rU
In version 9 this function is for Premium users, but after version 10 with the Play Store security policy changes and the elimination of the normal call notification this option has to be activated from the general configuration options and It is free for all users.
Thanks mate, really appreciate that and your amazing app
Start of tests of the new version:
The updating of the smartwatch can be done by loading it by USB or sending it using the update button on the information screen as shown in this video.
For the correct operation both applications have to have the same version.
When installing the development version the icon will change to green on both devices.
For users with WearOS devices that can not update the version on their smartwatch, send an email to develop.lumaticsoft@gmail.com to be included among the test users.
Release news:
• New notification system for navigation.
• New filter for multimedia notifications by combination of notifications. It will use the detection of notifications and combine them with the files received to be able to determine whether or not to send it.
• Improved system for registering filtered notifications.
• Possibility to select the application that notifies telephone calls.
• Bug fixed.
Apk
Watch Droid Phone 12.6.28
Watch Droid Assistant 12.6.28
Watch Droid Assistant - WearOS 12.6.28
Great work . Update looks amazing . Thanks for posting this
Which Navigation systems will this work with on the phone? Example I use Waze exclusively in my truck because i works best in conjunction with Ford Sync 3 system.
Unfortunately Waze does not publish the indications in the notification bar, at the moment it captures the navigation notifications:
• Google Maps
• Navigation for Google Maps Go
But in the future you can add other applications as long as you are posting the navigation instructions in the notification bar.
Great job @lumaticsoft…
Great Job… You are a Master!!!
you are the man great job,buenisimo, this is the developer edition and can we get replay messages and when or how we can replay like gmail,outlook and others, just quick replay, something else what can i do for not get two notifications, watchdroid notification and the system, i just want watchdroid notification filter.
thanks for a great job
Hi can you please work on supporting the ble always on Bluetooth system of kospet optimus pro?,it uses the uart technology to receive notifications,because your app is excellent but my battery drained from 100% to 82% in 1 hour,while with wiiwatcg(receiving that shitty notification)my battery drained only to 96% in 9 hours on watch and all notifications were received but in that shitty style,your app and Bluetooth 4.0 are consuming too much battery,can you please consider it(This happened on 12.0 PlayStore version)
Your choice of foul language adds nothing to your post. It isn’t necessary.
Foul language?,sorry but i didn’t use any foul language,I am just requesting and reporting,it might be my watch fault,I didn’t used any of your so called “FOUL” language,and I dont expect your comment,I am expecting Developers comment,if he says that he isn’t facing any similar type of response from any watch and might be problem of my watch,I wont ask again.
Please don’t divert my humble request to “FOUL” language,I just requested,If you have any suggestions then give solution.
Or not facing same problem on sane watch then tell me.
Please don’t give such wrong impression,I didn’t say anything bad about its app,“I LOVE IT” actually so please don’t put such comments for my comment.
Unfortunately I cannot determine what may be happening in your case or why you notice so much battery consumption.
Both the application of the phone and the smartwatch would have to spend between 1% and 5% of the total battery, according to the measurements I have made in the different devices that I have and the consumptions that users who test me in the different versions under test or before uploading them to the Play Store.
These values may vary depending on the use of Watch Droid, data transfer, number of notifications received, etc.
I use an application called Gsam to measure consumption both on the phone and on the smartwatch.
Unfortunately, many of the features of Watch Droid cannot be implemented correctly with BLE (Bluetooth Low Energy), also constantly trying to improve this, maybe in the future I can add a BLE connection with some features, unfortunately for the moment I do not think it is possible.
Likewise, if the application on the smartwatch is consuming more battery than the one mentioned above, verify uninstall and reinstall it, in general the battery cost does not have to be high.
By far the best control software for my Lemfo LEM T. Far more stable connection than on the recommended Wii2. I have encountered no problem with it save with music module that is asking for Wii2. I have encountered none of the problems mentioned here. I just had to revise several times the notification list as I selected too many -but that was my fault.
What I’d like to see in a forthcoming version is on the phone app some sort of notepad that would copy what I am writing on it simultaneously on any appropriate field on the watch. This is because I am very clumsy with my fingers and small keyboards (I have a broken right index finger which didn’t mend properly). -I am sure I am not the only one in that case. I know of at least one smartwatch control app that has this function. At home I connect a BT keyboard for that, but it’s hardly a portable solution.
Thank you,will check with game how much battery is getting consumed,love your work,this is great app
Hi
I am using watchdroid version 12…i am able to pick up call from the watch …but i dont know how to terminate the call from the watch .
At this moment works perfectly.
If you do not publish a new notification when the telephone application is answered, it will unfortunately not be sent to the smartwatch.
With this latest version, i was having a delayed in notification, sometimes it delayed for hours then i can see notification pop up on my watch, although my watch and the phone are always connected (connection time showing hours both devices had been connected). Any idea?
