Finishing the development of new functions to determine how the battery is used in your smartwatch. Much to finish and try I hope you can soon meet this and many other surprises…
There is bug in notifications history on watch (mostly im using widget to get there). Sometimes (mostly) when i select notification there show details other notification. I tried wipe a notifications history and this bug persist that. Im using newest google play version with deselected option “When not touching the notification generate record in the smartwatch”.
This incoming battery feature looks great on this screen
Dear lumaticsoft
My watch Droid assistant look like this now at my lemfo lem12
already uninstall and install again but still not fix the problem
can you guide me to fix this
I was able to duplicate what I see on your screen by changing the “Size of the icons” in the Button Style option, in the app, to the minumum setting. You can adjust them while observing them on your watch to get the desired size.
ok, noted
thanks Jonathan_Bickel
Bluetooth calling
Sorry I can’t reproduce the error, could you send a short video showing what is happening? Whenever I enter a notification from the notification bar, it appears correctly.
Thanks for your precise answer.
Ofcourse now everythink works correct
When this happen again i will try record video and analyze what event trigger that error.
Today i had this error 2 times. On third time when i found place to record video everythink was ok. But this wrong 2 notifications show up with vibration like new one. There is refresh-like event when notification is open?
Hello Lumaticsoft,
thank you for this super software, i really like the navigation feature on my Amazfit Stratos. Do you think it is possible to extend the navigation feature to other apps than google maps? I would like to use it with mapy.cz or locus maps while riding bike, that would be perfect.
Thanks friend, day by day I continue to work for users like you.
In order to make the navigation notifications to the application, you have to notify the different addresses, distances and coordinates in the notification bar, the only place where I have access to be able to send them to your smartwatch. I would have to review the way these applications work to see if this is possible, unfortunately at the moment I am designing some other features, I will leave it on the to-do list for when I have time.
Regards.
i have a rollme s08 that wont stay connected for more the 10 secs…wiiwatch is not an option.
i can stop and start music but the phone says not connected
all solved with the patience of a wonder man @lumaticsoft!
hi…been using your programme forever and love it…switched back to 9.0 recently as i need the option to start a call on my phone thru your app…i have bought a z fold 2 and am having following problem…when the screen of my phone is on and the wd app is on the screen everything works fine…as soon as i go to standby, switch off screen or even leave screen on and just put app in background, it does not work anymore…all usual backgroundcleaner apps have been activated or deactivated…all messages keep coming in fine, no problem…it is just the phone and music app that only works with the app loaded on my phone screen…any ideas?
With the Android 10 devices coming up, should we still use the old v9, or jump on the new releases ? What will we gain/miss on the old vs new version ?
Unfortunately the V9 has not been updated for devices with Android 9 and higher, unfortunately in these devices there are new permissions to request when working in the background. Watch Droid version 9 wasn’t ready for this. The new versions are, but unfortunately they do not have the ability to make phone calls like the V9 does.
Thats a shame . The dial function was my favourite feature when driving
the other day I was in power saving mode on my watch and accidentally turned on watch Droid much to my surprise it actually worked normally with the watch in power saving mode and was able to get longer life than I normally get but still with the functions of watch Droid working. Is this common knowledge or did I stumble onto something here
@lumaticsoft have you tested with any of the new Android 10 watches ?
I have just got the Prime 2 today, and I get many connect/disconnect popup on the watch, and when the watch app goes in the background, connection is totally lost. (But that goes for WhatsApp, Signal, Messenger Lite also, no connectivity when in background).
Working fine on A10 Lemfo . Have you tried what i suggested in your Prime 2 post
