Watch Droid Phone / Assistant
I don’t know if it will help, I have a dual ze 4 zeblaze. the connection with watch droid is very stable. I have only had disconnections when I used some other app in the smartphon that requires the use of bluethooht.
I thought they wanted him for the dial or call. Since only that was abandoned in the current version, or I’m wrong.
I don’t use the current one, because I use the version 9 dial on my watch that doesn’t have.
Is it possible to disable notifications for more then 1 message from the same sender (from whatsapp for example)?
So when I get the first message from the person X, I get notification on the watch, but if I don’t read it, it’s a little annoying to get 10 notifications if the same person sends me 10 messages in 1 minute :smiley:
Also, what are the main differences betveen the nast version and v9.1?
As I can see, in v9.1 it’s not possible to change icons quality, for example, right?
P.S: @lumaticsoft, you are doing a great job with this app!
Hi
I am unable to receive notifications from group chats in WhatsApp where only admins are allowed to reply…
I have a question for @lumaticsoft… I have the 9.1 version and I really want to go premium, because I need the widget feature… If I buy the premium version through the watchdroid app, will it automatically update to the latest version or it will stay to 9.1?
Unfortunately, because of the tests I have done in the Amazfit models, you can NOT play video, perhaps due to lack of codecs or some limitations of the manufacturers.
In order to play audios I have had to investigate a lot since they do not play like most smartwatch models and luckily and after a long time I was able to make WhatsApp Audio notes work.
This behavior has been informed to me by users with Android 5.1 devices, I really don’t know why maybe there is a problem with the firmware …
At the moment I have not had any device in my possession with this problem to determine better what can happen.
It is rare but most models work correctly and without disconnections but maybe some combination of phone => smartwatch have this problem.
Thank you if you have also informed me that when you connect your smartwatch via bluetooth call the connection stabilizes.
It would be a great function for the future, to group notifications and send them together, also with a delay in their time, it would have to see how a function could be done for this in the future.
Version 9.1 was the last one that requests permissions to make calls and take their data, version 13 is more current and has functions that 9.1 does not have.
Greetings.
I will see if I can check what happens with these notifications.
Thanks…:smiley::smiley:
It can be Premium without updating to version 13.
Thank you for your response and for your great app :slightly_smiling_face:
Very true as i did :+1:
Hi lumaticsoft, thanks for your reply and your work.
the strange thing is that not all Prime owner have this problem,as I read on the forum.
Could be it a problem with Android 10 phone ,as mine?
Thks again
I have the problem on my Kospet Prime, which is Android 7.1.1, so it’s not limited to 5.
And Phone is on Android 10, Huawei P30 PRO.
I test the application with Google Pixel models on Android 10 (Designed to have the Android system that Google releases without any modification of the manufacturers) before uploading any modification, I have also tested in Note 10 with Android 10 and I have a connection totally stable, unfortunately I could not guarantee that this is true for all phone models, but in those I have tried with Android 10 I have no problems.
Hi folks,
let me ask a question also here…
I have a Kospet Prime SE and I’m getting notifications that the watch is connected to the phone all the time (sometimes a few times a day and sometimes much more frequent), although the option for connection notification is turned off in the Watch droid app.
Is there a way to get rid of those notifications?
At first, I did not have this issue, but meanwhile, I changed a few things in my setup - I replaced Watch droid v13.x with v9.1 and also switched from stock launcher to the Universal launcher.
Did someone have the same experience and can help me with that?
EDIT:
I didn’t mention, the Watch droid assistant gives all those notifications.
@lumaticsoft, is there any way to make it stop sending notifications for established connection with the phone?
Hi dear
The connection is stable even on my note10 on android 10 and my prime but i have some problem with some function,When i go out from app on the phone i can’t shot a photo and play the music,the assistent ask me always to open the music app,and from record of phone notification on prime even if i push recall option the phone don’t recall,i deselected all optimization of app from phone and watch
That’s interesting, I didn’t experience such behaviour, although I didn’t use those functions, just a few times to try them.
However, unstable connection is not such a problem for me (because everything is functional, I’m getting notifications and so on), but let’s say 20-30 “Connected” notifications daily are driving me crazy.
