have you tried not using APK’s to do the volume change? I mean, arraytype 100 supports
com.android.settings.settings$SoundSettingsActivity and possibly volume setting as well. I haven’t thought about this, but it would streamline your watchface a lot!
tested com.android.settings.settings$SoundSettingsActivity and it takes you right into the volume sliders, very handy but not what you were looking for.
Are you using audiomanager.adjust.raise/lower for the volume call on the apk?
Thanks for contributing! I’ve not tried anything else because I don’t know anything about this, I just copied a few lines from all over the net (just had an idea and I didn’t see it implemented before, and I know nothing of android development).
Yes, I used audiomanager.adjust_raise/lower for this.
I’ll try out what you said when I get to open my pc again.
What it means Array type 100 support. I dont know about it. All though I have seen so many Array setting in clock xml file. What is the array setting for 9 o’clock on dial So that I could set volume control in my watch face of my finow x7
I need your help.
So many watch face having tap action for control like music, weather, dialer for there specific point to touch. Below is the example:- Touch at 5 digit for map. “Thor” is written on exact on top of 5 digit of dial of watch.
Here I have used this postion for other function
for camera open . In my watch dial position of 9 digit is unused .it is not assigned for any touch function. Here I like to set touch function for volume opening of watch by touching 9 digit.
So I want to know what is the correct setting of array type ------
Only below value of arraytype, X value and Y value.
rest thing I will manage any how.
I don’t know the value nor found any clue from other xml files of watch face.
I got android watch just two month ago, and I am in learning mode.
Below is example :-
Some one had made for thor watch ,where Map at Thor
