Sometimes on a video call or on watching a video clip, I would like to be able to turn UP or DOWN the audio volume. Is there a convenient way to do it without quitting the video and calling up a volume control app? I have seen Mr Smartwatch Ticks using a side slider to control the screen brightness. Is there a similar slider for controlling the volume?
Yes. Its called Volume Control by the same developer. Check Mr. Ticks videos to the link to his cloud page.
Hi. But this Volume app disapear, close after screen off. What to do?
But there is no this app in this menu. I mean Kospet Prime 2
Sorry . I dont understand . Install the app and follow the above instructions so it keeps running in the background . I cannot think any reason why the app wont work on P2
" Main menu - settings - apps and notifications - special app access - unrestricted data - then tap slider on the app you want to have unrestrcited data "
I installed app but there is no slider, no Volume app in this menu
Maybe you have Pro version ?
Sorry but i have never used this app so i certainly dont have pro version
No pro version. Please be patient, I am making a movie about setting up this app now. One or two days and you’re done. In the meantime, check out this movie to see how it works. I think it’s a very good little app. But the new movie will be a great help for accurate setup.
Thank you. Yes it is now working - both ! Many thanks.
I make a mistake because i do not correctly optimization but this second option with unrestricted area.
Btw i found the best clockface ( simple and elegant ) but it seams that weather is not working. Is possible to wearther working anyway ? Allcall w1 watch faces, Digital, watch faces, clock skins - ClockSkin
This is very common . Sadly we have to explain this over and over every week regardless of the instructions we post ![]()
Ok i must read the forum, i just started
thanks
There is also a solution for the weather.
A movie is being made about this as well.
