It’s done. It has not been easy for me to make all the necessary compromises. But for those who need a stocklauncher-version:
I’ve been away for awhile and am just back checking in. Thank you for all the hard work, time, and effort you have put into this project. I currently have the face installed and will give more feedback after someuse. Thanks again!!!
You are welcome. I’m looking forward for your Review!
Thank you for this great watchface. I have it installed with UL 3.4.8 but I loose constandly connection with my watch. Probally it will work with .watch version. Is that still W.I.P. ?
I still can’t offer a .watch version of this watchface. But it should work fine on UL 3.4.8? Just push the zipped folder to the clockskin folder on your watch.
Thank you for your quick reaction. I have uninstalled version 3.4.8 and installed version 3.4. It looks like connection is Stable now.
To avoid confusion: This face also works with the latest UL version.
Been using this face for a couple of weeks now. All features working well except ones you mentioned, which is still a great accomplishment. The tide chart is actually pretty accurate for my area which surprised me since I’m in North Carolina, USA. Thanks for a superb job!
Thanks for testing.
I’m glad you like it!
By the way: At the moment the solar time is identical to the simplified time. Test it…
Nice one! Cheers ^^
Thank you. I’m glad you like it!!!
Wellcome back @Jurgen_Oberst
Thanks mate!
Wow, that was an absolutely fantastic job!
Thank you! It was a lot of work in this case.
Hi G1NT0N1C , do you maybe have the season&zodiac section as a wheel?
thanks!
Ich verstehe die Frage nicht. Wofür brauchst Du es?
I want to use “port” this to amazfit and I could only implement that as a rotating pointer/disk.
I have already found several of my watch faces on amazfit and have had them all deleted. The last time it was a user called “Kannix” who used my work without asking. I expressly do NOT agree to the use of my watch faces. This applies to all of my watch faces. Please accept this.
