i used win 10 to flash successfully also
Win 10 is fine.
Just make sure you read up about disabling signed driver enforcement.
If you look on our YouTube channel or just YouTube in general - you will find how-to videos for installation of the VCOM drivers.
Search Google for ttyc0 wakelock. You get lots of hits. Maybe bad sim card.
Did you try to use a day in airplane mode? Then look at result.
Thanks for reply! (no sim card) I installed it earlier 3.0 Fw. All settings default,all night charger, first test (in table motionless) Airplane mode (from 100%) result 3.8% / hours. Then i switch normal mode (Wifi off,Bt off) 17% / hours. All firmware doing this. Now installed TWRP,Xposed,Magisk,BetterBatteryStats & Amplify… I’m testing it these days my last hope “Amplify” ,if don’t help me break it with a hammer …
Can we access the Lite OS files from the android side (with root ofc) ?
If so where can we find it?
In system/firmware folder, there are zips,that is lite os but the os is encoded as latest nordic sdk is used,so there doesn’t seem any way to edit lite os
I was facing the Same issue on My optimus pro… No matter what i did, some random wakelock sucked up my battery. Then i gave up on Kospet and tried Zeblaze thor 5 firmware(dont just flash the firmware as it is) and i am able to get amazing battery life of around 3 days and my watch sleeps like a baby… lol!
Edit: I was not able to add images. So here are some screenshots
https(colon)//ibb(dot)co/zG2tNYq
https(colon)//ibb(dot)co/bFrjHq2
https(colon)//ibb(dot)co/whcgyBv
https(colon)//ibb(dot)co/nwb2t5q
unbelievable to me…Thanks for the information.I’m looking for firmware …
Amazing results.
A how to would be welcomed by everybody.
Definitely great results. A setup info (BT, WIFI, SIM in/off) would be appreciated. And maybe an how to too…cheers
Yes everything works.i haven’t tested sim card…as I don’t use.i use only wifi and Bluetooth.
I got the firmware for thor 5 from xda. Just google thor 5 firmware and get it from the xda link(i am unable to post links here)
flashing steps:
- Copy the thor 5 system.img(replace the kospet system.img) to kospet firmware images directory.
- Now select the scatter file(make sure only system.img is from thor 5) rest all partitions are from kospet firmware.
- Unselect preloader, select download only and flash
- Factory reset once after booting into system(imp).
I guess the following is the xda thread you got the firmware from:
link
https://forum.xda-developers.com/smartwatch/other-smartwatches/zeblaze-thor-5-firmware-t3950535
btw, I think you will be able to post links now that you have reached the basic trust level
I dont use sim. BT on for 3-4 hours a day when i am in classroom. I use watchdroid.Wifi also i dont use much, only for around 1 hour a day.Screen on hand raise is on all the time.
Yeah… This is the one
In case anyone is afraid of using the download links in the xda thread, I certainly found them a bit scary, I have now downloaded the firmware and uploaded it to google drive:
Big thanks! I downloaded it from XDA. Based on this guide to flash, I did it. That’s how I got my “Optimus Thor” smartwatch.
All functions working,battery test coming soon. Thx.
After 2 day using,8:00h (batt.100%) -> 20:00h (batt. 45%) Bt on,(running Droid assistant) half brightness,notification 2-3 /hours = 4.6% / hours,i think it’s acceptable.
Optimus Pro Thor 5 firmware changes (default clock faces) :
Menu graphics & sequence
Day fitness datas
Have you noticed that battery life is better with Thor ROM then Optimus One?
