Thought it would be a good idea to create a thread for this to minimize confusion and OT discussion in other threads. Here we can discuss bugs, improvements, tips and so on.
Quoting some info from user theStrix (thanks!)
So basically original Kospet stock core but with Thor 5 system.
Just so that everyone knows - we have been testing the Thor 5 system image and so has the solution provider.
We are hoping to see what (if anything) is behaving differently between the two
Also I need to say that the wakelock behavior reported previously is NOT from within the system image.
It may be a kernel module causing it.
I am busy looking at the Thor 5 boot image as well.
Hi all, I have followed the instructions and I have been getting much better battery. I used the 2.6 Optimus FW along with the thor 5 .IMG
Currently with 3g, lift to wake and just below med brightness, kill background apps, no Bluetooth companion and not much usage in order to test, I’m getting a 2day estimated battery life. Before I was getting about 8-10H with similar usage.
