Have you followed the YT channel tutorial ?
Put internet and gps fine location on for this step.
Are you using WiiWatch or Watchdroid?
Ok. Now i understand. Gps didnt got fix and that why nothing happened. On outside everything works
As a assistance app im using Watchdroid.
To solve your Bluetooth problem, goto settings - more - backround Cleaner. Tap on battery saver and disable watchdroid.
Tbh i turned off battery saver. I will try now with turned on and added watchdroid and ul to exceptions.
watch droid must also be exempted from the battery saver on the smartphone.
On phone battery saver too have exception on watch droid.
About ul on kospet i have sometime bug that when i scrolling menu then launcher switching to lower menu ie. when i scrolling launcher settings switching me to apps menu. When i scrolling apps menu then switching to widget.
Can i ask two questions? The first one is relevant to the topic.
I have the universal launcher new gen. Can i set a watchface in full screen? I tried to maximize my watchface and it is cropped on four sides.
And second but not relevant, I heard that it is an app that makes tapping to the edges of watch screen easy, but I cannot find the name of it.
Any help would be useful, I am a new user of smartwatch (Kospet Prime).
Have you got your watch in square mode ? . Your faces should be full and round ?
I tried to change between the square and round display option, but I didnāt achieve anything.
My faces are full and round, but they donāt fill the screenā¦They leave a black ring around them⦠And when I try to maximize the watchface from the universal launcher settings, they are cropped. I didnāt face this problem with the official launcher (kospetās launcher).
Press and hold the face. Set scale value (the slider) to 0.
Make sure you reboot the watch after changing to round mode.
Thank you, it helped! Great launcher
Do you have any idea what is the app that helps tapping on the edges of the screen? Like at fb messenger, I cannot push āsendā button.
New version for bug fix :
Version 3.0.4 :
https://drive.google.com/open?id=1GuQCEd10I73vqlrLD-3uEjQkEFe4qc40
play.google.com/store/apps/details?id=com.ricktop.ClockSkinCoco
On my Prime animations in UL arenāt smooth, they are updated about 4 frames / second. On my other watches they are smooth. Is there a setting somewhere Iām missing?
hi,install setting search,accessibility,triple tap for zoom.
https://apkpure.com/settings-search/com.katzoft.settings.search.full
hi Eric,ClockskinCoco is the new UL version
Ok ,stupid question,I installed it and now try it.
thks
AWESOME THANK YOU ERIC!
Need I ask what the bug was?
Thank you my friend! I have heard about this app, but I didnāt know that it has that feature and I was searching for days!
