Thanks for your reply. I’ve downloaded a launcher switch from Play Store so I can turn on mobile data from the stock launcher. This will do me until an update comes out
I tried and it works, I had to deactivate airplane mode … So it worked
Zeblaze thor 4g pro
How did you deactivate airplane mode?
Zeblaze Thor 4 pro
Hello.
How long does the battery last for you in the Always on Display mode of Kospet Optimus?
When I set the entire black dial (color 000000), amoled should not shine at all and consume energy, but consumes about 10% of the battery per hour.
And when set, always on in Android uses only 2% of the battery per hour.
It seems that the always on display mode in the universal launcher does not work correctly with the amoled display.
Hi. I am new to the forum and I am a little lost in it.
I am from Spain and I have some problems with English, but I will try to express what the google translator allows me.
I am using the universal launcher (Oh God Eric haha) but I have some questions:
Is there any way to eliminate the timer and the calculator built into the universal launcher?
When I put the clock on the timer it is VERY difficult to return to the initial screen. -
I deleted the Google browser to use Google Go and Google launcher widgets do not work. I guess it will be because I deleted Google.
Is it recommended to use the Go versions of Google on watches? For example, the Maps?
I think that 1 of ram in Lem 9 is little, so I preferred to use these apps.
A greeting!
Sadly, you can’t compare aod using Android main cpu with aod using the simplified cpu…
- No you can’t disable. Just don’t swipe to it. To return easily, just swipe with your finger on top or bottom of the watch, not in centre part.
- I don’t know
Eric_Crochemore
You couldn’t change the refresh in always on display to 1 minute?
This would definitely reduce battery consumption.
This doesn’t change much (i’ve tried)
Ok. Thanks for the answer.
Thank you, Eric! I will learn to master it. xD
A little help needed please. Since i’ve installed the Universal Launcher my bluethooth connections drops every second. I searched the forum for a solution but I could not find one. Love the launcher and i would like to continue with it. Any ideas?
Go to watchsettings - more - backround cleaner. Tap on the Text, disable watchclockskin.
There’s probably no relationship between UL and bluetooth. At least, i don’t see one.
Maybe a permission is not granted?
Maybe the problem is on the phone side
For me, if the bluetooth and the wifi are activited together, i loose the connection maybe similar.
(Optimus pro)
Hi, i have problem with UL. Weather feature dont work. I cant even change main location. When i click “…” button nothing happen. Temperature is always 0 degree. Im too have problem with bluetooth connectivity but i think its not launcher problem.
