Is the .gwd format supported???
Not in Android watches, no
Thank you, is there no way to make it compatible?
If itās getting coded then it will compatible⦠
But what is this format ? Is it really used ? What will be the benefit comparing to other formats already supported ?
Well for one thereās quite a huge library of gwd (gear watch designer) faces for users to choose from
For example
Thanks for the reply! And how can this decode be done?
https://www.watchfaces.be/gear-tactical-v-8/
I love it
but is .gwd
Sorry man, this is above my skill level
Moreover itās Ericās launcher, he could tell you best
decode can be done by coding this new format⦠The problem is that it seems thereās several version of this format and they are very different⦠And also, i donāt have any reference for this, that means i have to guess how itās coded (like i did with watchmakerā¦)
So, a lot of work, is it worth it ?
Well since you put it that way, itās not worth it I guess
Did you ever get the mobile data to work? As Iāve a Thor 4 running this launcher and I get exactly the same problems
Make sure that you are running the newest UL Version.
Yes! The 4g also works
Yes I thank you, but Iām still the latest version
I sold Thor 4 two months ago sorry, I canāt try with latest launcher release
How did you get that to work? The only way I can turn in mobile data is to switch launchers. Iāve checked for updates on my UL and nothing is avaliable. I wonder if can get a rom for it?
Normally on latest version, you can show the mobile data setting screen using UL.
Yes it shows the mobile data settings screen when I click the mobile data icon, but there is no way to turn on mobile data from the settings.
Or is there? Many thanks for your reply
Well, it may depend on your watch fw, maybe thereās no solution for you excepted using the stock launcher.
