Ok, I see, have you tried fixing the button?
I canât fix it, I asked if there is another way to enable this function, it turned out that there isnât
Isnât it in Power saving then like in this video : https://www.youtube.com/watch?v=NFWagIv8hFw
at 19:33
Is it possible to put a Bluetooth connection indicator on a skin which showing connection status?
No sorry . Thats not possible . Thanks
Installed 3.0.1 beta on KV88 pro about android 7, everything seems to work, but in any dial, instead of the day of the week, incomprehensible seconds run.
Try this version instead : https://drive.google.com/open?id=1BRVLSacciB1NIp_noHan9V4BQ1og__bQ
Class, the day has been fixed!
But now even worse, the dial has moved to the lower left corner,
exactly the same as in version 3.0
but itâs not in full screen mode in the center.
PS. I reinstall oldest beta ver. 3.0.1 and day weeks works fine!
Reboot the watch now.
Kospet Optimus Pro issues:
On my new Kospet Optimus Pro watch, the heart rate seems to work only when the watch face is showing. As soon as the display turns off, the green light at the back turns off, which means it stopped measuring heart rate.
My understanding was that the launcher will check the hear rate periodically ? Please clarify.
Many Thanks.
No hr is measured when skin is shown, thatâs all. I donât replace what a specialized application will do. Itâs only to update the skins.
Wow that smart watches can be sooo complicated.
Thanks for make this. But it is a study. Like it took me a while that I did not have android wear but I have an android 6 watch.
So I nanaged ot install Universal Launcher New Gen which seems the be the same as clockskincoco since after downloading clockskincoco it asked if I wanted to replace allread installed app.
Anyways. I lost my settings icon. So I cannot go to wifi or bluetooth or any other stock android settings. I only have a few âUniversal Launcher New Genâ settings. Is that on purpose?
What about wrist gestures? My watch has an accelero meter so it should support wrist gestures but I never saw anything in the old settings. And in âUniversal Launcher New Genâ I put it on time out 3 seconds but of course thats a setting to turn of the screen. Where is the setting to turn on the screen? if my watch does not support it are there apps that can force this? Like I said the accelerometer is there and working it just needs to be read some how .
A factory reset should solve your problem.
@Eric_Crochemore I have a .watch clockskin which is not working on your launcher can you please check it,I have sent you a pm
I finally got my new phone this weekend (order 26 june :)) and it connects fine with the Finow q1 pro. I thought it would be the watch since both phone and tablet failed but a new phone solved it.
But that leaves my question that I cannot get to the android settings when I use âUniversal Launcher New Generationâ. So I have to set the original laucner as home to get to the android settings to say configure wifi or remove devices from bluetooth.
You can enter the watchsettings via the appdrawer. There are a setting Icon. But if you run the newest Version of UL, all shortcuts from the UL settings are working fine. Bluetooth for Bluetooth on/off, Same for WLAN, GPS, Mobile data. Iâm not sure that understand your problem. If there is no setting Icon in the app drawer, try a factory reset.
Make sure that you
- have installed the newest Firmware
- have installed the newest UL
Hi Eric
Iâm a big fan of your work since the first version of the universal launcher.
When the launcher supported files .watch I dowloaded a lot of them and I liket that many has the version with low brightness. I know that the way to activate it is on the skin settings, but exists a way to configure this skin as the default face with the function of move the wirst? And then when the user tap the screen activate the normal skin?
I have the optimus pro and the battery has improved over the time so I see an oporttunity if this is possible.
Best regards
This is called the âalways onâ mode on the launcher.
Hi G1NT0N1C
Thank you for taking time to reply.
If with firmware you mean my watch is running latest available os I think it is. I ran several ota updates until it said my watch is up2date.
The UL if from the market is the latest. The play store says: installed
I really miss the settings app and the bluetooth app too. It is on the watch. When I run the original launcher it is there. From this launcher I go throug all the system apps until I find âmore appâ all my installed apps are there.
Nova launcher does not see them either thought some are shown. I beging to suspect that all updated apps are shown in UL and Nova but not the system apps that did not get updated?
Thanks Eric but I referred to switch automatically between the low brightness skin and the normal brightness skin. And not necessary use the always on display mode.
