Big News, i found the black screen after update to 3.0.x issue !!
It seems your watch is running on 64bits OS !! And 64bit is the big new functionality that Google forced me to put on this 3.x version…
So you’re the lucky beta testers as i don’t have a 64bit watch, at least if i have one, i don’t know which one…
To make it short i’ve found a solution, so if you’re interested to test and have one of these watches, i will share this special version. Let me know.
Eric, this one works fine. Thanks!
Which version is 64-bit?
just written above… since 3.x
I have makibes m3(same as kospet optimus)all dual os watch are 32-bit checked system files,no dual os watch is 64-bit,UL 3.0.x is working perfectly(much better than before,for some reason UL used restart sometimes and black screen came,now its not happening)so i dont think so its because of 64-bit.
Eric - I asked gin where to find help for the UL - are you that source?
Just installed it and found it doesn’t reflect accurate moon phases (static on half), heart led flashes continuously and measurement also changes and steps are not accurate (showed 5000+ when I started out this morning)
Can you help?
Moon has been discussed just above.
Heart is normally working when the skin is visible and off when not.
About pedometer, there’s a reset function if needed.
Two questions: 1) Does the referenced ClockSkinCoco-3.0.1.apk solve the problem?; and, will the steps reset daily to zero (after resetting)?
Yes and yes
Hello! Please tell me how to turn on or off the movement of the hand, the button does not work?
Main Settings - gesture - screen on raising . Thanks
I do not have such settings, the Finow x5 plus watch, and the watch does not have a universal launcher
If you havent installed universal launcher you do not need to ask questions in the universal launcher section . All watches do not come with this installed as standard . What exactly is wrong with your watch ?
I installed universal launcher, but there is no such setting in launcher
There is, but on Finow watch this UL setting has no effect. So use the System settings instead.
And in the system settings there is no such thing, every time you have to exit UL, turn it off and back to UL again
No, in UL open the “system setting” icon, then in “gesture”, toggle on or off the “wrist raise”.
are you turning the function on and off so often that it will be a problem doing it this way?
I do not have such items
Yes, because it greatly affects battery life.
