Out of curiosity, is your zoom set to square? If so, change the zoom back to full screen, then restart your watch. Just a thought... everything is centered but icons are huge...do i have to change the dpi
Oct 4, 2017 22:07:31 GMT 1schung78 said: Out of curiosity, is your zoom set to square? If so, change the zoom back to full screen, then restart your watch. Just a thought…
everything is centered but icons are huge…do i have to change the dpi
thanks,you guys are great…is there a way to update the weather on a watch face without having to update the weather app manually
when i press on the right side of my watchface i do not get the apps that appear like a caroussel
will this feature work with any watch face?
On my lemfo LES1, with version 2.3.2 very often when I double tap to the main screen I cannot change/nor reset the screen. Nothing happens, I get no error. How I can fix it?
swipe to the right to the apps menu, then go back to the launcher. If you still facing the problem, do it again but from the menu, go to settings - date/time - set the time, go back to the launcher.
you could try with the hibernation manager, you can’t stop it but at least put it in a sleep mode.
It would not solve the problem with changing watch face not showing up, I’m still working to find out what the reason could be.
Maybe this is a stupid question, but here I go: Is this launcher compatible with Watch Droid Assistant and Watch Droid Phone apps? Would the notifications get in the way having the watch USB tethered?
Oct 5, 2017 22:24:40 GMT 1oscarhmeza said: Maybe this is a stupid question, but here I go: Is this launcher compatible with Watch Droid Assistant and Watch Droid Phone apps? Would the notifications get in the way having the watch USB tethered?
Bonjour Éric, quelle est ta recommandation concernant la lecture de sms en Bluetooth sur un smartphone, depuis une lemfo les1 [wiwear,wiiwatch,watch droid,etc…?] Sans mettre en cause l’intégrité de ton coco launcher, ce qui est ma priorité! et sans consommer trop de batterie! Ce qui n’est pas le point fort de cette montre…Merci et bon week-end
Oct 7, 2017 6:50:31 GMT 1bringhton said: Bonjour Éric, quelle est ta recommandation concernant la lecture de sms en Bluetooth sur un smartphone, depuis une lemfo les1 [wiwear,wiiwatch,watch droid,etc....?] Sans mettre en cause l'intégrité de ton coco launcher, ce qui est ma priorité! et sans consommer trop de batterie! Ce qui n'est pas le point fort de cette montre...Merci et bon week-end
This choice mainly depends on your phone, if you have a solid link with wiiwear or wiiwatch that’s OK. If not you can try watch droid that is Amazing too, the drawback of this one is that the notifications will not go through the launcher but in a proprietary interface, but that’s also an advantage for some people. So, no recommandation, it depends on your phone and display preferences.
Thanks for the 2.3.2 ver. Nice work. But some bug still in the program. Battery indicator still bad. Show me 92%…after then turn off the watch, and i plug in the charger, and show the display (battery 1%).
Oct 7, 2017 14:29:55 GMT 1hans65 said: I’m not sure but I think debloater works only if the device is rooted. Some of the system apps could disabled it Android 5+ is installed
I have Finow X5 air not rooted and I use Debloater without any problem
Install on My PC and use ADB comands to communicate with my watches then use Debloater to freeze apps this is what u can do if you are not rooted
Watch launcher, some apps and communication app is freeze
I use Watch Droid Phone to communicate with my watches from my phone (love this programm)
