Sept 28, 2017 14:11:36 GMT 1 dezsocsaba said:
Hello Eric!
    Your Launcher looks great, and it works in a DM98 android 4.4.2 smartwatch too. The only problem is the resolution (320x240), it have got a wider screen, and white area in the right side.
if the skin could be centered…and and the backgound could be the same ase the clock skin… it could be usuable with Lemfo LEM4, Domino DM98 etc.
Rectangular display are not supported.
I bought a FiFine w9 really cheap on ebay (24 dollars shipped to the UK!), it has android 4.4, 1gb ram 8gb rom and an mtk6572, this launcher has given it some life, it will now go into roatation with my lem4 and les1, thanks for all your hard work Ricktop!
does this watchface facerepo.com/app/faces/details/vmetalblack-sky-v0119r-free-14d8fad3608 works for you guys? It’s buggy on my DM368 so I wonder, if it’s because of my watch or launcher.
It is working on Q7
Sept 29, 2017 11:40:23 GMT 1 hans65 said:
It is working on Q7
Thanks, maybe DM368 is a little bit different, because also calendar tags or pedometer doesn’t update smoothly.
Hello Éric, “compass” function is forecasted to be introduced in a further version of your launcher? Thanks again.
Oct 1, 2017 17:08:06 GMT 1 bringhton said:
Hello Éric, "compass" function is forecasted to be introduced in a further version of your launcher? Thanks again.
No, this takes too much power.
After working a while with the 2.3.2 version, I got some problems. The launcher very often crashes. I could not see the watch face.
So I went back to 2.3.1 and wait for the next version. I’m having a Q7 watch
At least share the log file if you want help.
Hi Eric,
First of all, thanks for your work, it is great and I love your launcher. I personally don’t care if I have the version 2.3.1, 2.3.2 or 2.3.x installed on my watch, I like it anyway. I flashed it so there is no log file to send you. After I’ve installed the lower version, I’m still facing some problem.
I’m came to the conclusion, the problem is not your launcher, it is my watch or android it self. I think the most problem here described are from android, because the keep all the files and apps in the ram. So I’ll tray to using a cleaner app to see if this would help.
juz asking
can this app install in KW18?
Oct 3, 2017 3:00:01 GMT 1 harsaad230 said:
juz asking
No, it’s not an Android watch.
I’ve just installed it, it looks great, thank you. Is in roadmap to add the feature to download watch faces directly from the smartwatch?
Oct 3, 2017 9:17:47 GMT 1 lorenzol said:
I've just installed it, it looks great, thank you. Is in roadmap to add the feature to download watch faces directly from the smartwatch?
No plan to do that.
how can i uninstall the app
can’t uninstall because this pcakge is an active administrator
i have a q7 watch and does not work
ok i got it…was not easy to use with q7
Hi Erick, for the record: Tested in both KW88 and S99 watches and it works like a charm until now. No battery drain, most watchfaces works as expected (some few with glitches/bugs). Thanks for your awesome work.
Hi gnr
What kind of problems have you had on your Q7? The uninstall from the launcher is actually very easy. I also have a Q7.
No plan to do that.
Again thank you for your work, please keep going
hello Ricktop with version 2.3.2 in my zeblaze thor when you put sim 3g the watch face goes black and does not return even when rebooting and you can not choose another watch face, a similar problem happens when using wiiwear with bluetooth
Oct 4, 2017 7:01:45 GMT 1 hans65 said:
Hi gnr
nothing is centered
icons are too big
